×I am trying to populate a text field based on issue type:
<!-- @@Formula:
String s = issue.get("issuetype").getName();
if (s == "Other") return "This is of issue type other";
s is getting populated with "Other", however, when I compare it in if statement I do not see the output.
Thanks!!
You can cast the value, that should work
if (s.equals("Change Relationship")) return (int)issue.get("customfield_11501");
Try
s.equals("Other")
Yup, that worked and it's Java implementation. Things makes so much more sense now
Hi Peter,
I am trying to calculate a number field but I do not want to display the decimal point. Is there a way to convert a field value to whole number?
This is giving no result. customfield_11501 value is 51 and it displays 51.0 when I display it as it is.
value=issue.get("customfield_11501");
return numberTool.format(value);
Thanks!!
You are welcome
