MS Active Directory Group Membership not updating
Aron Felberbaum
We have the Jira instance integrated with Microsoft Active Directory (Read Only, with Local Groups).
When we added a new member to a group Active Directory, Jira did not refresh the list of members from that group.
We tried a manual sync, but don't work.
No errors in the logs.
We use JIRA v6.3.4a
Aron Felberbaum
There was a local group with the same name as a local group. Since there is an existing local group, the group membership of the AD group is not being pulled. Even after deleting the local group, the AD group membership is still not updated because each membership per user on that group is saved in JIRA and is tagged as "local" (cwd_group.local = 1). More details on the issue:https://confluence.atlassian.com/display/JIRAKB/Membership+For+Group+Is+Not+Updated+After+Synchronisation
Piotr Klimkowski
February 5, 2015
So the full sync didn't work ? That's quite mysterious as it should clear all the users and memberships and recreate if from scratch.
Actually in JIRA 6.3.5 the AD synchronisation was reworked, maybe it's worth to check this out.  See this: https://jira.atlassian.com/browse/JRA-26458
Aron Felberbaum
I have the following 3 AD groups and JIRA shows number of users 15, 43 and 8 respectively .
JIRA Users
JIRA Developers
JIRA Admins
However in AD we got 42, 42 and 7 respectively.
No errors in the log:
2015-02-05 16:57:05,940 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteDirectory] synchronisation for directory [ 10002 ] starting
2015-02-05 16:57:06,002 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [directory.ldap.cache.UsnChangedCacheRefresher] found [ 31 ] changed remote users in [ 62ms ]
2015-02-05 16:57:06,002 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [directory.ldap.cache.UsnChangedCacheRefresher] scanned and compared [ 0 ] users for delete in DB cache in [ 0ms ]
2015-02-05 16:57:06,002 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteChangeOperations] deleting [ 0 ] users
2015-02-05 16:57:06,002 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteChangeOperations] deleted [ 0 ] users in [ 0ms ]
2015-02-05 16:57:06,002 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteChangeOperations] scanning [ 31 ] users to add or update
2015-02-05 16:57:06,002 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DirectoryCacheImplUsingChangeOperations] scanned and compared [ 31 ] users for update in DB cache in [ 0ms ]
2015-02-05 16:57:06,002 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteChangeOperations] updating [ 27 ] users
2015-02-05 16:57:06,580 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteChangeOperations] updated [ 27 ] users in [ 578ms ]
2015-02-05 16:57:06,580 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DirectoryCacheImplUsingChangeOperations] synchronised [ 31 ] users in [ 578ms ]
2015-02-05 16:57:06,627 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [directory.ldap.cache.UsnChangedCacheRefresher] found [ 0 ] changed remote groups in [ 47ms ]
2015-02-05 16:57:06,627 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DirectoryCacheImplUsingChangeOperations] scanning [ 0 ] groups to add or update
2015-02-05 16:57:06,627 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteChangeOperations] scanned and compared [ 0 ] groups for update in DB cache in [ 0ms ]
2015-02-05 16:57:06,627 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DirectoryCacheImplUsingChangeOperations] synchronized [ 0 ] groups in [ 0ms ]
2015-02-05 16:57:06,643 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [directory.ldap.cache.UsnChangedCacheRefresher] scanned and compared [ 0 ] groups for delete in DB cache in [ 0ms ]
2015-02-05 16:57:06,643 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteChangeOperations] removing [ 0 ] groups
2015-02-05 16:57:06,643 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteChangeOperations] removed [ 0 ] groups in [ 0ms ]
2015-02-05 16:57:06,643 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteDirectory] INCREMENTAL synchronisation complete for directory [ 10002 ] in [ 703ms ]
And here is my settings:
Directory ID: 10002
Active: true
Type: CONNECTOR
Created date: Thu Sep 04 11:57:40 EDT 2014
Updated date: Thu Feb 05 16:57:06 EST 2015
Allowed operations: [CREATE_GROUP, DELETE_GROUP, UPDATE_GROUP, UPDATE_GROUP_ATTRIBUTE, UPDATE_USER_ATTRIBUTE]
Implementation class: com.atlassian.crowd.directory.MicrosoftActiveDirectory
Encryption type: sha
Attributes:
    "autoAddGroups": "Jira Users"
    "com.atlassian.crowd.directory.sync.currentstartsynctime": "null"
    "com.atlassian.crowd.directory.sync.issynchronising": "false"
    "com.atlassian.crowd.directory.sync.lastdurationms": "969"
    "com.atlassian.crowd.directory.sync.laststartsynctime": "1423173425674"
    "crowd.sync.incremental.enabled": "true"
    "directory.cache.synchronise.interval": "300"
    "ldap.basedn": "dc=mycompany,dc=local"
    "ldap.connection.timeout": "10000"
    "ldap.external.id": "objectGUID"
    "ldap.group.description": "description"
    "ldap.group.dn": ""
    "ldap.group.filter": "(&(objectClass=group)(&(cn=jira*)))"
    "ldap.group.name": "cn"
    "ldap.group.objectclass": "group"
    "ldap.group.usernames": "member"
    "ldap.local.groups": "true"
    "ldap.nestedgroups.disabled": "true"
    "ldap.pagedresults": "true"
    "ldap.pagedresults.size": "1000"
    "ldap.password": ********
    "ldap.pool.initsize": "null"
    "ldap.pool.maxsize": "null"
    "ldap.pool.prefsize": "null"
    "ldap.pool.timeout": "0"
    "ldap.propogate.changes": "false"
    "ldap.read.timeout": "120000"
    "ldap.referral": "true"
    "ldap.relaxed.dn.standardisation": "true"
    "ldap.roles.disabled": "true"
    "ldap.search.timelimit": "60000"
    "ldap.secure": "false"
    "ldap.url": "ldap://fmgad1.mycompany.local:389"
    "ldap.user.displayname": "displayName"
    "ldap.user.dn": ""
    "ldap.user.email": "mail"
    "ldap.user.encryption": "sha"
    "ldap.user.filter": "(&(objectCategory=Person)(sAMAccountName=*))"
    "ldap.user.firstname": "givenName"
    "ldap.user.group": "memberOf"
    "ldap.user.lastname": "sn"
    "ldap.user.objectclass": "user"
    "ldap.user.password": "unicodePwd"
    "ldap.user.username": "sAMAccountName"
    "ldap.user.username.rdn": "cn"
    "ldap.userdn": "jirasrv@mycompany.local"
    "ldap.usermembership.use": "false"
    "ldap.usermembership.use.for.groups": "false"
    "localUserStatusEnabled": "false"
Piotr Klimkowski
February 5, 2015
You might want to check if all conditions for incremental sync to work properly are met, see here: https://confluence.atlassian.com/display/JIRA063/Connecting+to+an+LDAP+Directory under "Enable Incremental Synchronisation" Also, check if disabling the incremental sync in directory properties helps (alternatively disable and enable this directory or simply restart jira, it's all the same). There should be "Full synchronisation completed successfully" in the logs. If the incremental synchronization turns out to be a problem I strongly suggest checking out JIRA 6.3.5 or newer.
Aron Felberbaum
I disabled incremental sync and members are still not added.
2015-02-06 09:36:51,871 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteDirectory] synchronisation for directory [ 10002 ] starting
2015-02-06 09:36:51,981 CrowdUsnChangedCacheRefresher:thread-2 INFO ServiceRunner     [directory.ldap.cache.UsnChangedCacheRefresher] found [ 3 ] remote groups in [ 110ms ]
2015-02-06 09:37:22,404 CrowdUsnChangedCacheRefresher:thread-1 INFO ServiceRunner     [directory.ldap.cache.UsnChangedCacheRefresher] found [ 5730 ] remote users in [ 30533ms ]
2015-02-06 09:37:22,591 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteChangeOperations] scanned and compared [ 5730 ] users for delete in DB cache in [ 172ms ]
2015-02-06 09:37:22,591 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteChangeOperations] scanned for deleted users in [ 172ms ]
2015-02-06 09:37:22,591 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteChangeOperations] scanning [ 5730 ] users to add or update
2015-02-06 09:37:22,607 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DirectoryCacheImplUsingChangeOperations] scanned and compared [ 5730 ] users for update in DB cache in [ 16ms ]
2015-02-06 09:37:22,607 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteChangeOperations] updating [ 7 ] users
2015-02-06 09:37:23,185 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteChangeOperations] updated [ 7 ] users in [ 578ms ]
2015-02-06 09:37:23,185 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DirectoryCacheImplUsingChangeOperations] synchronised [ 5730 ] users in [ 594ms ]
2015-02-06 09:37:23,185 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DirectoryCacheImplUsingChangeOperations] scanning [ 3 ] groups to add or update
2015-02-06 09:37:23,232 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteChangeOperations] scanned and compared [ 3 ] groups for update in DB cache in [ 47ms ]
2015-02-06 09:37:23,232 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DirectoryCacheImplUsingChangeOperations] synchronized [ 3 ] groups in [ 47ms ]
2015-02-06 09:37:23,232 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteChangeOperations] scanned and compared [ 3 ] groups for delete in DB cache in [ 0ms ]
2015-02-06 09:37:23,544 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteChangeOperations] removed [ 1 ] user members from [ Jira Developers ] in [ 281ms ]
2015-02-06 09:37:23,544 atlassian-scheduler-quartz1.clustered_Worker-2 INFO ServiceRunner     [atlassian.crowd.directory.DbCachingRemoteDirectory] FULL synchronisation complete for directory [ 10002 ] in [ 31673ms ]
Piotr Klimkowski
February 9, 2015
From the log at hand - I don't know, ask support maybe ? Maybe turn the debug logging on for crowd, but it will be huge.
Register now
