Macro to show labels
Joe Harmon
Anyone know a way to show the list of labels attached to a certain page?  I am using the page properties report to show specific page content and properties, but I don't see a way to show the labels associated with a page within that report.
Davin Studer
November 11, 2014
You could do this with a simple user macro.
## Developed by: Davin Studer
## Date created: 11/11/2014
## @noparams
#set( $i = 0 )
#foreach ( $label in $content.getLabels() )
#if($i > 0), $label#else$label#end
#set ( $i = $i + 1 )
#end
Or if you want something a little more stylized ...
## @noparams
<span class="label-list">
    <span class="aui-label">
        <a class="aui-label-split-main" href="/label/$content.spaceKey/$label">$label</a>
    </span>
#end
</span>
Davin Studer
November 13, 2014
Does this meet your needs?
Joe Harmon
I'll check it out. I must not have enough rights to create a user macro.
Davin Studer
November 14, 2014
Yeah, you have to be a system administrator. But you could try passing the code to a sys admin and see if they would create it for you.
Henning van Ackeren
May 9, 2018
both flavors don't work for me when just pasting them into Confluence 6.4.3.
Maybe they need an update?
(My understanding of user macros is very limited, so I could not debug myself.)
Henning van Ackeren
May 9, 2018
Oops, just realised that it's only about how some characters are rendered here. E.g. the greater than character is rendererd as ">
Sorry for the noise.
Sergio Andreozzi November 7, 2024 edited
This is a very simple and useful macro. I'd suggest Atlassian to consider adding as part of the standard macros. We have created in Confluence 8.9.3 with the same formatting of native confluence labels as follows:
Macro Name: page_labels
Macro Title: Page Labels
Description: Displays all labels associated with the current page, formatted like native Confluence labels.
Macro Body Processing: No macro body
Output Format: HTML
#set($labels = $content.getLabels())
#if($labels.size() > 0)
  <div class="labels-container">
  #foreach($label in $labels)
      <a href="/label/$space.key/$label.name" class="aui-label-split-main">$label.name</a>
    </span>
  #end
  </div>
#else
  <p>No labels assigned to this page.</p>
#end
