This question is in reference to Atlassian Documentation: Testing database access speed
when trying to run the test from this article under Ubuntu i run into the following problem:
/opt/atlassian/jira/jre/bin/java -cp /data/AS-4339/atlassian-log-analysis-0.1.1.jar:/opt/atlassian/jira/lib/postgresql-9.1-903.jdbc4-atlassian-hosted.jar \ com.atlassian.util.benchmark.JIRASQLPerformance \ jira asdfasdfasfas \ 'jdbc:postgresql://localhost:5432/jiradb' org.postgresql.Driver
when i run it i get
Fehler: Hauptklasse com.atlassian.util.benchmark.JIRASQLPerformance jira konnte nicht gefunden oder geladen werden
roughly translated:
Errror: Main class com.atlassian.util.benchmark.JIRASQLPerformance jira could not ne found or loaded
java seems to regard the parameter for the database user name as part of the classname (marked in bold).
how do i fix that?
Okay sometimes you just have to replace the spaces you copied from atlassians article manually.
Please, would it be possible to elaborate a bit on this solution? I encounter the same error and I can't find the mistake when running this command. What spaces you mean? Thanks in advance.
Hey, i dont remember exactly but i think it was the space after the last "e" here:
For postgresql.Hope this will help someone.
java -cp ./atlassian-log-analysis-0.1.1.jar:/u0/tom/postgresql-9.4.1212.jar com.atlassian.util.benchmark.JIRASQLPerformance user passwd 'jdbc:postgresql://xyz.com:5432/jira?autoReconnect=true&useUnicode=true&characterEncoding=UTF8' org.postgresql.Driver
