Make FixVersion Required only on specific Resolution Types
Peter Kahn
April 25, 2016
Hi all,
How do I require FixVersion on resolution transition only if specific resolution type chosen?  At present, I use Required Field validator which forces fix version chosen for all resolution types but I really only care for fixed/won't fix and not for duplicate.
Is there a way to use a validator in an if?
Jeremy Gaudet
April 25, 2016
I've done this using a Script Runner scripted validator.  I broke it up into two separate validators for ease of modular deployment, they are:
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.project.version.Version;
import com.opensymphony.workflow.InvalidInputException;
Collection<Version> fvs = issue.getFixVersions();
Boolean hasFV = (fvs != null && !fvs.isEmpty());
String fixedResolution;
switch (issue.getIssueTypeObject().getName()) {
    case "Sub-Defect":
    case "Bug":
        fixedResolution = "Fixed";
        break;
    case "Improvement":
        fixedResolution = "Implemented";
        break;
    default:
        fixedResolution = "Completed";
        break;
if (hasFV && issue.getResolutionObject().getName() != fixedResolution) {
	invalidInputException = new InvalidInputException("If \"Fix Version/s\" is set the resolution must be \"" + fixedResolution + "\".");
String errorString;
    case "Sub-Defect":
    case "Bug":
        break;
    case "Improvement":
        break;
    default:
        break;
if (issue.getIssueTypeObject().isSubTask()) {
	errorString = "\"Fix Version/s\" (synched from the parent issue) is required when specifying Resolution of \"" + fixedResolution + "\".";
} else {
	errorString = "\"Fix Version/s\" is required when specifying Resolution of \"" + fixedResolution + "\".";
if (!hasFV && issue.getResolutionObject().getName() == fixedResolution) {
	invalidInputException = new InvalidInputException(errorString);
The "RequireFixedIfFixVersion" validator covers your "Duplicate" case, in that it won't let them set a FixVersion for anything except the valid "fixed" terminal states.  You can adjust as needed, of course, these are just examples of how I did it.
I implemented these as script files in /home/jira/jira_data/scripts, for ease of re-use, but if you only have one or two transitions you need them on, and only one workflow, then inline is likely the way to go.
Jeremy Gaudet
April 25, 2016
Oh, and don't mine my "(synced from the parent issue)" part; I have a script listener that syncs fix version to all sub-tasks, so that they don't have to be set manually, and can't drift away from the parent.
Peter Kahn
April 25, 2016
@Jeremy Gaudet thanks for sharing.  nice solution.
Peter Kahn
October 14, 2016
Funny, I just tried this and am getting the following error which seems really weird as I'm not importing that class nor can I seem to find that other class or its javadoc
An unknown exception occured executing Validator
com.atlassian.jira.workflow.SkippableValidator@635ba7c5:
root cause: No signature of method:
com.innovalog.jmwe.IssueProxy.getFixVersions() is
applicable for argument types: () values: []
