Make a custom field required based on another custom field
Nanda Kishore Reddy.G June 4, 2015
I have 2 custom fields in issue creation page in jira. They are IP Release, IP Recipient. IP Release contains 2 radio buttons with 2 options "Yes", "No". IP Recipient is Multi line text box. My Requirement is if we select "Yes" option from IP Release , then IP Recipient should be changed to "optional" to "mandatory" and if we select "No" option from IP Release , then IP Recipient should be changed to "mandatory" to "optional"
custom fields Id s are
IP Release --> 12431
IP Recipient --> 12435
Yes --> 23832
No --> 23833
I solved this issue by adding groovy script code in script validator. But I want solution for this without script validator. Please help me to solve this one.
Thanks in advance.
Nanda Kishore Reddy.G June 7, 2015
Hi Marcus,
Thank you for your suggestion. But Behaviours plugin is deprecated right?  As per my requirement I want validation with plug in development in jira. Please can you help me to solve this issue with plug in development.
Thanks in advance.
Marcus Silveira
June 5, 2015
Hi Nanda,
I believe this may be possible with the Behaviours plugins.
hope this helps
Learn more
