Make a custom field required based on another custom field
Brian Sherman March 11, 2013
My Jira version is 5.2.6 and Behaviours plugin is version0.5.3
I have a custom field that is called Production Cut-in that has a select list of Yes or No. If the user selects Yes I need to have another custom field called ECP marked as required, if the user selects no than the ECP field should not be required. I am new to groovy scripting and am not sure if I wrote the script correctly. Here is what I came up with:
FormField pro = getFieldById("customfield_11505")
FormField ecp = getFieldById("customfield_11506")
if(pro.getValue().contains('Yes')){
 ecp.setRequired(true)
}else{
 ecp.setRequired(false)
Any help would be greatly appreciated.
Thanks.
Prashant Mali
You can try this for newly added custom fields on issue screen (version 7.1)
import com.onresolve.jira.groovy.user.FormField
FormField test1 = getFieldByName("test")
FormField test2 = getFieldById("duedate")
String str=test1.getValue()
String str2=test2.getValue()
test2.setRequired(true)
test1.setRequired(true)
if(test1.getValue() == "1")
log.error("************ WELCOME in first loop ************")
else
log.error("************ WELCOME in second loop ************")
test2.setRequired(false)
Amit Pratap Singh June 5, 2013
Hi Vidic,
how we can run above script for a specific project in jira?
do we need to create custom event for this or we need to use post-function?
Vidic Florjan
April 11, 2013
You can try also ...
FormField pro = getFieldByName("Name_of_f_no1_not_ID1")
FormField ecp = getFieldById("Name_of_f_no2_not_ID2")
String vpro = (String) pro.getFormValue()
String vecp = (String) ecp.getFormValue()
//to see values near fields uncomment sentences
// pro.setHelpText("vpro: "+ vpro)
//ecp.setHelpText("vecp: "+ vecp )
  if (vpro == "Yes") {
  }else{
JamieA
April 11, 2013
Line 2 should be getFieldByName too I think...
Andrei [errno]
April 10, 2013
have you been able to find a solution?
Alexandru_Iacob
March 12, 2013
You may want to consider also this solution for making a custom field required based on another custom field: http://confluence.kepler-rominfo.com/display/TR/Make+a+custom+field+required+based+on+another+custom+field, using the JJupin plugin and its Live Fields feature.
JamieA
March 11, 2013
Hrm, getValue() was introduced partly to avoid this need to look up an option by ID, or to hard-code an option ID, which makes it hard transferring code from dev to prod.
If you print the value that getValue() returns, you might find it's not a list, or it doesn't contain what you think.
Add
log.warn ("value returned was: " + pro.getValue())
Then tail your atlassian-jira.log, and refresh the page.
Jamie,
I added the log.warn ("value returned was: " + pro.getValue()) and it said the value returned was null. Any ideas on this?
JamieA
March 12, 2013
Does getFormValue() return anything?
you should also
log.warn (pro)
to make sure the field is actually found...
Brian Sherman March 12, 2013
Yes getFormValue returns -1
JamieA
March 12, 2013
-1 sounds suspicious, that's not a valid option ID. What does log.warn(pro) say.
Christian Czaia _Decadis AG_
March 11, 2013
Hey,
I would use the option ID for the "Yeas" value e.g.:
if ((pro.getFormValue() == "12135") {
Either way, you should use getFormValue() and not getValue() AFAIK.
Cheers
Christian
March 11, 2013
Hey,
I would use the option ID for the "Yes" value e.g.:
Cheers
Christian
