Make field with options to be available to tick
Jovita Sajonaitė September 17, 2020
Please check attachment - is it possible with Inisght help to create such field with functionality like this?
There are several Data sources added where you would have possibility to check two options : "Requested" and "Delivered", if both fields are checked, you would be able to select date from calendar which is under "Date of delivery" option.
Rudy Holtkamp
Hi @Jovita Sajonaitė ,
Out of the box this will be hard to do, but with an app like Proforma this would be possible. You can try it here: https://proformademo.thinktilt.net/ and the marketplace listing is here: https://marketplace.atlassian.com/apps/1215833/proforma-forms-checklist-for-jira?hosting=server&tab=overview
Rudy
Register now
