Making custom field text red?
Raju KC
March 27, 2013
How to make custom field text red?
<script type="text/javascript">
AJS.$("#customfield_11329").attr('style', 'color:red')
</script>
Above code does not work. Any ideas?
RambanamP
March 27, 2013
In that way it does't work on 5+ jira version, try with this
&lt;script type="text/javascript"&gt;
jQuery(document).ready(function($) {
	JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function (e,context) {
		callFunction();
		callFunction();
	function callFunction(){  		AJS.$('label[for=customfield_11329]').css({color:'red'});
&lt;/script&gt;
Raju KC
March 27, 2013
Great. It works!!
But only in edit screen, not in view screen.
RambanamP
March 27, 2013
glad to hear it worked!!
if it to be work on view screen you need to check custom field id on view screen
if my answer helped then vote up and accept as answerd :)
Dan27
hello @RambanamP ,
Is there any idea how can I do it for edit too?
RambanamP
November 6, 2018
@Dan27 the above script will work on edit screen too, just you need to replace customfield id(you can get field id by inspecting element)
Dan27
Thank you
@RambanamP,
This text has no id.. only "title" , and it id inside div that has id.. How can I write it in your code?
RambanamP
November 10, 2018
@Dan27 can you share html content of a customfield on edit screen?
RambanamP
March 27, 2013
try with this
AJS.$('label[for=customfield_11329]').css({'color':'red'});
or
AJS.$("#customfield_11329").parent('label').css('color','red');
Raju KC
March 27, 2013
Does not work!!!
Raju KC
March 27, 2013
</script>
RambanamP
March 27, 2013
how you tried and whatis the jira version?
RambanamP
March 27, 2013
can you share your code? i tried now it is working
Raju KC
March 27, 2013
It is 5.1.5 version,
Still not working
Joe Moreno
September 29, 2015
@Rambanam Prasad In which file do I need to edit this?
RambanamP
September 29, 2015
@Joe Moreno you no need to edit any files, just add code in accepted Answer in Announcement banner for testing, once it worked as expected then i suggest to add this code as web resource module in a plugin(you will get lot of post on this forum if you need to know how to add it in plugin) Note: don't forgot to change customfield id :)
KL Kumar
@RambanamP I have similar requirement where I need to change the mandatory field labels in Red. But here I am using ScriptRunner Behavior script and it is not working. Here is my code snippet.
// requiredFields has the list of mandatory fields labels.
for(String field in requiredFields){
field = field.trim()
log.warn("Field ::"+field)
String js = "<script type=\"text/javascript\">\n"+
"jQuery(document).ready(function(\$) {\n"+
"JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function (e,context) {\n"+
"callFunction();\n"+
"});\n"+
"function callFunction(){\n"+
"AJS.\$('label[for="+field+"]').css({color:'red'});\n"+
"}\n"+
"});\n"+
"</script>"
log.warn(js)
def FormField f = getFieldByName(field)
f.setLabel(js)
Any help is highly appreciated.
RambanamP
June 29, 2018
callFunction();
callFunction();
</script>
add above code on announcement banner by changing cusotmfield id
am not sure how to include javascript using behavior.
KL Kumar
@RambanamP Thank you. This works well for custom fields. Can this be possible for system fields? I want to show system fields also in Red.
RambanamP
July 4, 2018
yes, just you need to change replace customfield id with system field id
callFunction();
callFunction();
AJS.$('label[for=summary]').css({color:'red'});
AJS.$('label[for=components]').css({color:'red'});
</script>
KL Kumar
@RambanamP Thank you!
It works...
Mani September 1, 2018
@RambanamP  I have tried your script and its working fine.
I have a custom field with "*" at the end of the label.  Is it possible to make only the "*" in Red color instead of whole text?
Thanks in Advance.
RambanamP
September 5, 2018 edited
@Mani you need to try something like follows if you want to add red asterisk, if you have already asterisk and want to make red color then use CSS to make it red
AJS.$("#customfield_11300").parent().children('label').append('<span class="aui-icon icon-required"></span>');
Like • alex likes this
Bunty
@RambanamP,
Thanks for your reply!
The script is working fine but custom field(version Picker(multiple versions) text is not changing to red color. Need total text to be in red color.
Tried with below script
callFunction();
callFunction();
</script
Bunty
@RambanamP
Any help?
RambanamP
September 6, 2018
can you share the HTML content for the custom field?
Bunty
Hi @RambanamP,
 I don't see any option to get HTML content. It's a Version Picker(multiple version) custom field not default one.Capture123.PNG
Bunty
@RambanamP,
HTML content for CMS TestVsersion/s field
<td id="custom-fields-customfield_11110-name">
<strong>CMS Test Version/s</strong>
<div class="secondary-text description">Specify the version(s) on which the defect has been tested.</div>
</td>
<td id="custom-fields-customfield_11110-type" class="nowrap">
Version Picker (multiple versions)
</td>
<td>
Bunty
@RambanamP
Any help?
RambanamP
September 19, 2018
is the above code from create/transition screen?
Bunty
I took HTML content from the web page.
MAG-II
Hi -
Is it possible to change the color of the field values for system fields? I am hoping to change the values for Labels to red.
Anyone have any ideas?
Register now
