Mandatory Field
JIRA Team Mailbox February 8, 2016
We have a custom field which comes in to the popup screen in the middle of the workflow. How can we make it mandatory ? when we make it mandatory using field config, in the issue create screen it gives an error ? is there any workaround for this ?
Nic Brough -Adaptavist-
February 8, 2016
Use a workflow validator to check that the field is populated.  They stop the transition if validation fails, and put the user back on the transition screen if there is one.
Is there any simple configuration change without writing any script or code ? or is there any pluggins for this ?
February 8, 2016
Yes.  Add a validator to the workflow.
JIRA ships with several, but most of us install the JIRA Suite utilities to get some more useful ones.
atlassian, social impact bingo, may it forward, atlassian foundation, community engagement, atlassian community events, atlassian learning, social impact challenge, volunteering, community kudos, atlassian social impact, atlassian community
Come one, come all!
Hey everyone! Are you ready to make a difference? Join the Atlassian Social Impact Bingo event! ❌⭕
Play Bingo! 🙋🏻‍♂️
