we are trying to introduce voting feature for just one project. In this case, I need to find a way to hide every vote functionality by default, but activate for the mentioned project.
I'm running into problems by hiding the vote button in activity stream. I don't want to manipulate Jira's source code to get this work (explained here: http://blog.networkedcollaboration.com/2012/03/19/editing-jira-activity-stream-css).
When I use this code in the announcement banner, I can hide the button by adding an css to the header of every iframe:
AJS.$(document).ready(function() {
AJS.$("input#testbutton").click(function () {
AJS.$("iframe").each(function (index) {
var frm = this.contentWindow.document;
var otherhead = frm.getElementsByTagName("head")[0];
var link = frm.createElement("link");
link.setAttribute("rel", "stylesheet");
link.setAttribute("type", "text/css");
link.setAttribute("href", "vote.css");
otherhead.appendChild(link);
As you can see, this code gets triggered by a click on a button, placed in the announcement banner, too. So after finishing load of page and iframes, I can hide the vote button by firing this click event of the testbutton.
What does not work is executing this code on every iframe's load event:
AJS.$("iframe").load(function() {
I tested the load event in a single html file, that includes two iframes. There it works quite good! Placing this in Jira's announcement banner nothing happens. I tried to use the load event to raise an alert message, this does not show up, either. So my conclusion is, that the load event is not fired.
Anyone with a suggestion here? :)
Thank you in advance!
I finished up with the following solution/workaround:
this is not a good one , but a solution, that works.
