I have a requirement to get the 'Resolved by' value for a issue from a plug-in. This information has to be extracted from the history, changegroup and changeitem tables of JIRA. Is there a possible way of getting this information using the ofBizDelegator? If so how could I combine these two entities to get the data I require? or is the only option to use direct database queries?
could someone please point out a link which highlights how to combine multiple entities with selection criteria based on both entities using the ofBizDelegator?
Use ChangeHistoryManager to getAllChangeItems() of the issue. Looking into the ChangeHistoryItems where the field (getField()) "status" was changed to "Resolved" (using the values of getTos()) you can determine the user (getUserKey()) who changed the issue.
This worked perfectly, Thank you very much for the prompt response.
Register today
