Can you explain?
What do you want to be color or bold?
The lable with the field name or the content value of the field?
Are you using jira server or cloud?
OK,
Go to your "field configuration scheme"
find your field there, on the right side of the field you will see "Renderers"
Click on it and change it to "wiki style render"
Once you save, your custom field free text will be of type rich text, so you will have all these options:
And you can bold/color as you like
Hi - From the above comment "Are you using jira server or cloud?" and the resulting guidance I'm guessing this is not possible on Jira Service Desk tickets? We would like to embolden the custom fields shown in this screenshot, all fields are created using single or multiple select list.
The reason I ask is due to the Description field being bold but others arent so it looks odd.
Hi @Karyn Tooke ,
Same question, are you using Service Desk cloud or server?
Your screen shot refers to the issue view, am i right?
Hi Nir - Thanks for the prompt response, we are using SD cloud solution, yes its the issue view.
