I had a recurring problem where users were getting obtuse errors when trying to transition issues. The core problem was that the workflow transition required a comment but they weren't providing one. The resulting error message didn't make this clear. I was enforcing the required comment by adding the Comment Required Validator to the workflow. This worked fine with Jira 4.4.3. After I upgraded to 5.1.8 I started getting popup errors.
Steps to reproduce:
The error screen displays:
Cause:
java.lang.IllegalArgumentException: Cannot find expected argument 'errorMessage' in parameters.
Stack Trace: hide
The error message in the logfile is: 2012-11-26 18:29:56,594 http-8080-57 ERROR 500ErrorPage.jsp Exception caught in 500 page Cannot find expected argument 'errorMessage' in parameters. java.lang.IllegalArgumentException: Cannot find expected argument 'errorMessage' in parameters.
This is especially frustrating because the error seems to be upstream of the actual problem, so I can't see the errorMessage that's missing and use that to debug the core problem.
Damn and blast. No sooner did I post my question than I found my answer. I forgot to upgrade the Jira Misc Workflow Extensions plugin when I upgraded Jira. Upgrading to v2.5.4 solved my problem. D'oh!
