Math-Time Expression required for JWT plugin post function
SWAPNIL SRIVASTAV
We want to populate a Date and Time picker custom field while using the JWT post function "Create issues and subtasks" with the following logic:
If System Time <16:30:00, then Date part of the field - same as system date and Time part of the field - System Time+ 30 Minutes.
If System Time >16:30:00, then Date part of the field - next working day and Time part of the field = 10:00.
Could you please help us with the math/time expression for above logic, so that we can use the same while creating issues.
Any help would be appreciated.
Thorsten Letschert _Decadis AG_
Hi @SWAPNIL SRIVASTAV ,
what you're trying to implement should be absolutely possible.
Could you please further elaborate the schedule you're thinking of, e.g. specifiy your 'working days' (MO - FR?) as well as the starting time for each day?
I got you covered regarding the following examples:
  • Today 12:05 > Today 12:35
  • Today 18:00 > Tomorrow (if tomorrow is a working day) 10:00
  • Today 23:59 > Tomorrow (if tomorrow is a working day) 10:00
I'm curious about the exact limits starting from 00:00 (assumptions following):
  • Today 00:01 > Today 10:00
  • Today 09:45 > Today 10:00
  • Today 10:05 > Today 10:25
Cheers
Thorsten
SWAPNIL SRIVASTAV
Hi @Thorsten Letschert _Decadis AG_ ,
We have come up with it :
and it is working fine. Any improvements are welcome.
Swapnil Srivastav
August 19, 2019 edited
first of all congrats to coming up with a valid solution yourself.
With regard to future maintainability, personally I'd prefer a more generic approach using schedules (see the documentation).
First, create a schedule, e.g. called Business Hours using the expression
MON-FRI{10:00-16:30;}
Afterwards, use this schedule within your expression, that's then is as short as (00057 is the field code for Current date and time):
inSchedule({00057}, "Business Hours", LOCAL) ? {00057} + 30 * {MINUTE} : nextTime({00057}, "Business Hours", LOCAL)
Update: just saw that you were skipping weekends when adding those 30 minutes. To do so, the correct expression would be:
inSchedule({00057}, "Business Hours", LOCAL) ? addTime({00057}, 30 * {MINUTE}, "Business Hours", LOCAL) : nextTime({00057}, "Business Hours", LOCAL)
Short explanation of the expression above:
  • Check whether current date and time is within the schedule provided
  • If so, just add 30 minutes
  • If not, use the next date/time that would be in schedule again
The advantages, apart from a shorter expression, lie primarily in the future maintainability and flexibility in editing the business hours (e.g. taking holidays into account, using different hours per weekday, etc.).
Cheers
Thorsten
Like • Max Foerster - K15t likes this
