This is related to this question: https://community.atlassian.com/t5/Jira-questions/how-to-mention-a-JIRA-issue/qaq-p/300801
This feature worked great until a few weeks ago. Now it does not work at all for me. Is there a setting somewhere that would reenable this? Or is there a bug somewhere else with all the new Jira changes.
Has there been a fix to this? This is a critical issue to us
Hi Nathan,
could you clarify the your situation?
1. What is your platform cloud or on-promises?
2. What it is the version installed?
As I know this feature should work.
Anyway, firstly please check this links https://confluence.atlassian.com/jirakb/mentions-are-not-working-in-jira-applications-289277743.html
Gonchik Tsymzhitov
Using Jira cloud, so not sure the version is relevant, and I can't find one shown anywhere.
As for the two links, those refer to mentioning other users, not issues. Mentions for users (@mentions) work, but referencing other issues (i.e. "XYZ-123") no longer automatically inserts a URL with current in-line status in the UI.
Let me know if there is anything else I can provide.
Looks like in Cloud now it is ok.
Is it actual?
I just noticed today that this is only an issue with the new interface. If I am editing the description or adding a comment from the new interface (Backlog sidebar or Active Sprint pop over when clicking on an issue) this auto linking/mentioning does not happen. Although if I open the issue view directly (in a new tab for example), both comments and description edits work as before.
Let me know if you can reproduce.
Clicking on issue in Backlog, then adding issue number in description or comments does not work for me.
@Gonchik Tsymzhitov this is still an issue. not sure if you have any harder line to atlassian, but its quite annoying to have it work sometimes but not always.
