Merging Custom Fields / Text fields?
chefkoch June 4, 2013
Within our Mantis setup we have the fields:
  • Description,
  • Steps to Reproduce and
  • Additional Information
Is is somehow possible to merge all of these into "Description" while import or afterwards?
It would be great if we could add headers in between like:
%description%
# Steps to Reproduce #
%steps to reprodude%
# Additional Information #
%additional information%
Wojciech Seliga
June 5, 2013
It's not possible without modifying the source code of JIRA Importers Plugin. However it should be relatively easy. Every JIRA commercial license holder has the access to the source code of JIRA Importers Plugin.
You would have to modify com.atlassian.jira.plugins.importer.imports.mantis.transformer.IssueTransformerVer118OrOlder class and concatenate the info (fields) you want and set description (setDescription()) of ExternalIssue class.
chefkoch June 10, 2013
For our production system we "only" had a open source license. So we bought the starter license now to get access to the source code and will use a customized importers-plugin. Thanks for the tip.
Ruchi Tandon
June 9, 2013
I would suggest to import the fields anyways into JIRA as custom fields, and then you can choose one of the following options to copy the field value from custom field to the system fields :
Ben
March 2, 2016
Hi - are running any of these scripts possible in JIRA Cloud?    See my related question https://answers.atlassian.com/questions/37522200
