I am trying to connect to MS flow to Jira using following option but it needed API Token. I did not see API Token or password option. Looks to me my MS flow is old version it seems.
I have Jira server version hosted in my organization . Its not in cloud. In cloud easy to generate API Token but Looking the way to generate API Token and integrate MS flow.
Here is the screen shot that I am referring to connect to Jira.
How I can successfully connect. Any advise.
Om
Nope.
