we migrated 2 different jira system. we see everything looks good but some of the data elements are set as blank.
also sub task are mapped to wrong project for example subtask A mapped task id B under C project. After migration sub task A mapped task id D under E project.
we need to do a manual clean up. is there any soution for this. ?
Lakshmi
It very much depends on how you did the merge and what went "wrong" with the data that seems to be wrong.
I'm afraid this isn't really one we can help you with unless you can describe how you did the merge and the exact problems you have.
