Migrating Data from Azure DevOps to JIRA
Deepali Bagul
Hi All,
Can someone please guide me on how to migrate data from Azure DevOps to the Jira server? I want to migrate only tickets that are filtered using the Azure DevOps query. I understand that we can do an export and import the issues into JIRA but we would lose history (when an issue was moved from a particular state to another, etc.)
This would be important since we would like to move from Azure DevOps to Jira but not lose the history. I would also want to migrate attachments, issue links, comments, and avatars that are attached with the ticket.
Deepali Bagul
Craig Nodwell
April 13, 2022
Importing from a formatted JSON file may be the way to go.
It allows for History, Attachments....
From this page:
Importing Data From JSON
deepali3031
Thanks @Craig Nodwell ! This is helpful. I am trying to get generate the JSON file through REST API.
Deepali Bagul
@Nic Brough -Adaptavist- @Yasir Mehmood Can you please guide me, thanks!
Alfredo Negrete
Were you able to migrate Azure Devops instance to Jira?
