×Hi, we have a script using JIRA API to copy issues to another instance of JIRA. Everything is working but I cannot map the Development Field used for GitHub requests.
Is it possible to set these value and keep the request status?
Hi @Ritche
Welcome to the community!
As far as I understand it the Jira Development integration uses issue keys to map the field. So as long as the issue keys in your other instance aren't identical to the original keys you probably can't map your existing GitHub integration to the new instance/project.
Thanks Luka
