I have a issue with migrating HSQLDB to MySQL. I try to migrate it via your instruction
https://confluence.atlassian.com/display/DOC/Migrating+from+HSQLDB+to+MySQL
But migration toolkit return empty SQL file. I copied DB from /var/atlassian/application-data/jira/database 2 files:
jiradb.properties and jiradb.script
After finishing all steps from instructions I got empty file. Here is log file:
-- MySQL Migration Toolkit Report --
-- Title: Summary Of The Migration Process --
-- Date: 2014-12-16 11:05 --
1. Schema Migration
Number of migrated schemata: 1
Schema Name: PUBLIC
- Tables: 0
- Routines: 0
- Routine Groups: 0
- Synonyms: 0
- Structured Types: 0
- Sequences: 0
Details:
- Tables
- Views
- Routines
- Routine Groups
- Synonyms
- Structured Types
- Sequences
2. Data Bulk Transfer
End of report.
Is there a reason you are not using "export to xml" in your HSQL installation, and then "import from xml" in your MySQL installation? It's easier, safer and supported by Atlassian...
