Migration of jira and server-id
Marco Schauer February 24, 2015
Hello, we want to migrate our JIRA and Confluence installations to a new server machine.
We want to user our production-licences on that new server. Whats the best way to transfer the licence to this new server? Just change the server-id in my account an use the license on the new server?
The old server instance will be shut down after migration.
Thank you for your help
Best regards Marco
Boris Berenberg
February 24, 2015
Just go ahead and move it. Everything will work fine. The license will be properly migrated as part of these instructions. Instructions for JIRA: https://confluence.atlassian.com/display/JIRA/Migrating+JIRA+to+Another+Server and Confluence: https://confluence.atlassian.com/display/DOC/Migrating+Confluence+Between+Servers
Marco Schauer February 25, 2015
Is ist possible, to run both installations on different servers parallel for a few days, to have the old system running until all works perfekt on the new system?
Will that be a problem with the licence?
Will it be possible to install nthe new instance an perform on day X a final backup on the old server and restore on the new server?
Boris Berenberg
February 25, 2015
This is fine, as along as you don't run the two in parallel long term you are just performing a migration and we have no issues with this. In fact, we encourage you to run them in parallel and perform your testing in your test environment. Your license will continue to function as expected.
Like • Jeff Yantha likes this
Thanks a lot for your lightspeed support!
Register today
