Milestones seems not to appear on gantt chart for jira
Joan Dela Cruz
April 13, 2014
Milestones seems not to appear on gantt chart for jira even if issue was tagged as milestone. Green diamond sign is not showing.
Frank Polscheit
April 15, 2014
Hi Joan,
if you are running JIRA 6.x, please download my pre-v3.1.2 from my server at http://www.polscheit.de/plugins/jira/gantt-chart/gantt-3.1.2-JIRA6.jar and install that JAR-file via "upload" button on JIRA's page "manage add-ons". Then open your browser's console (also see my wiki: https://polscheit.atlassian.net/wiki/x/DgBM) and switch back to Gantt-Chart. Within the console, you should see a lot of additional information, like sample below:
configured Gantt Options customfield id = customfield_10004 / DEMO-6: is milestone = false (having set milestone option id = 10000") batch.js?source=webContextStatic:9480
configured Gantt Options customfield id = customfield_10004 / DEMO-8: is milestone = false (having set milestone option id = 10000") batch.js?source=webContextStatic:9480
Object {self: "http://localhost:2990/jira/rest/api/2/customFieldOption/10000", value: "Milestone", id: "10000"} batch.js?source=webContextStatic:9480
configured Gantt Options customfield id = customfield_10004 / DEMO-12: is milestone = true (having set milestone option id = 10000") batch.js?source=webContextStatic:9480
configured Gantt Options customfield id = customfield_10004 / DEMO-5: is milestone = false (having set milestone option id = 10000")
Please copy and paste all the console output into the body of a support request (see menu item on screenshot below: clicking on it will automatically open a standardized email) for further analysis.
Frank
Frank Polscheit
April 15, 2014
Problem solved: configuration mismapping for Gantt Options customfield.
Jose M.
June 26, 2014
We use jira 6.1.5. If while creating issues the gantt milestone option is not coming, so maybe we have to check if the steps mention above were followed. Do we?
Frank Polscheit
June 26, 2014
Please use menu item "support request" available within the menu of the "?"-icon to write an email, which will automatically create a related issue with my JIRA. That's easier than processing this on Atlassian Answers, here.
Based on your request above: don't you see the customfield "Gantt Options" having a checkbox for milestones? If not, than contact your administration to configure the related edit- and view-screens to contain that customfield, which is not done automatically by installing the add-on (this would not make sense as you can have multiple screens depending on individual settings).
Frank
Jose M.
June 29, 2014
Thanks for the answer. Yes, I will use the "Support Request" process in future, but in some cases along with "Atlassian Answers".
