Missing sort functionality from sub-tasks in JIRA 7.4
Sven.H
August 15, 2017
Hi everybody,
We have made an upgrade from JIRA Software 7.1 to 7.4.
We are missing the functionality to sort subtask in the task view.
Is this a bug or what can we do to use this functionality again?
Sven
somethingblue
August 16, 2017
Hi Sven,
I did the same and have not run into this issue:
Screen Shot 2017-08-16 at 10.42.39 AM.png Screen Shot 2017-08-16 at 10.42.50 AM.png
If you're unable to sort your subtasks I would first try JIRA in Safe Mode to see if there is an add-on causing this behavior.  If you're able to sort in Safe Mode re-enable the add-ons one by one until you determine the culprit.
Next I would verify whether you have an announcement banner with javascript and if so, see if removing the announcment banner helps.
Branden
Sven.H
August 16, 2017
Hi Branden,
thx for your support.
We have tried your suggestion.
We have set the save mod. But the arrows don’t get displayed.
Our field for the announcement banner  is empty.
Sven
Let's build A Rovo Agent 🤖
Save your spot
