MissingMethodException on com.onresolve.jira.groovy.jql.HasSubtasks.getValues()
Jason Smith April 22, 2015
This is a (slightly trimmed) version of an example of an error sequence. I've been noticing variations on this ever since our upgrade from 6.3.15 to 6.4.1.
2015-04-22 16:26:48,374 ajp-bio-8009-exec-2114 WARN pmull1 986x473750x4 4w2wcv /rest/inline-create/1.0/context/bootstrap [com.atlassian.ozymandias.SafePluginPointAccess] Unable to run plugin code because of 'groovy.lang.MissingMethodException - No signature of method: com.onresolve.jira.groovy.jql.HasSubtasks.getValues() is applicable for argument types: (com.atlassian.jira.jql.query.QueryCreationContextImpl, com.atlassian.query.operand.FunctionOperand, com.atlassian.query.clause.TerminalClauseImpl) values: [com.atlassian.jira.jql.query.QueryCreationContextImpl@c6559759, ...]
Possible solutions: getIssues(), getClass()'.
2015-04-22 16:28:41,028 ajp-bio-8009-exec-2008 WARN pmull1 988x475031x6 4w2wcv /secure/views/bulkedit/BulkOperationFinish.jspa [action.issue.bulkedit.BulkOperationProgress] Bulk edit bean unexpectedly null. Perhaps session was lost (e.g. when URL used is different to base URL in General Configuration)?
2015-04-22 16:29:50,103 ajp-bio-8009-exec-2095 WARN pmull1 989x476407x5 4w2wcv /rest/inline-create/1.0/context/bootstrap [com.atlassian.ozymandias.SafePluginPointAccess] Unable to run plugin code because of 'groovy.lang.MissingMethodException - No signature of method: com.onresolve.jira.groovy.jql.HasSubtasks.getValues() is applicable for argument types: (com.atlassian.jira.jql.query.QueryCreationContextImpl, com.atlassian.query.operand.FunctionOperand, com.atlassian.query.clause.TerminalClauseImpl) values: [com.atlassian.jira.jql.query.QueryCreationContextImpl@c6559759, ...]
2015-04-22 16:29:56,330 ajp-bio-8009-exec-2119 WARN a.pi 989x476507x3 kae1f4 /secure/RapidBoard.jspa [com.atlassian.ozymandias.SafePluginPointAccess] Unable to run plugin code because of 'groovy.lang.MissingMethodException - No signature of method: com.onresolve.jira.groovy.jql.HasSubtasks.getValues() is applicable for argument types: (com.atlassian.jira.jql.query.QueryCreationContextImpl, com.atlassian.query.operand.FunctionOperand, com.atlassian.query.clause.TerminalClauseImpl) values: [com.atlassian.jira.jql.query.QueryCreationContextImpl@a842c126, ...]
I looked at both scripted fields we have, and neither of them seem to make use of getValues. We don't have any script listeners configured.
We are using getCustomFieldValue, but isn't that different? We're also using getInstance, getChangeHistoryManager, and getPreviousIssueKeys.
Any ideas?
Chris Solgat
May 3, 2015
I've just found out that it may be related to an Agile board.  I've noticed that the error only appears when a certain Kanban board is loaded.  When I pull up the filter that the board is using in the Search Issues screen, I don't get the error.  It's only on the board.  I opened a ticket that you can follow here - https://jamieechlin.atlassian.net/browse/GRV-702
This could still be related to the link that Jamie put in, since it has to do with some inline edit code.  I would imagine that the kanban boards would rely heavily on that.
Chris Solgat
April 27, 2015
We have just upgraded to JIRA 6.3.15 and Scriptrunner 3.0.14.  We are seeing the exact same WARN message in our logs.
2015-04-27 11:52:32,173 http-bio-8529-exec-31 WARN  712x9072x1 uv05u6  /rest/inline-create/1.0/context/bootstrap [com.atlassian.ozymandias.SafePluginPointAccess] Unable to run plugin code because of 'groovy.lang.MissingMethodException - No signature of method: com.onresolve.jira.groovy.jql.relations.SubtasksOf.getValues() is applicable for argument types: (com.atlassian.jira.jql.query.QueryCreationContextImpl, com.atlassian.query.operand.FunctionOperand, com.atlassian.query.clause.TerminalClauseImpl) values: [com.atlassian.jira.jql.query.QueryCreationContextImpl@bcb107a3, ...]
We do not have any custom script listeners or scripted fields.
Jason Smith April 27, 2015
Does anyone think it's amusing that Adaptavist took it over and now suddenly there are weird problems? Not exactly the Midas touch.
Chris Solgat
April 27, 2015
I turned on Debug for com.atlassian.ozymandias and was able to pull this stack trace - Possible solutions: getIssues(), getClass()'. groovy.lang.MissingMethodException: No signature of method: com.onresolve.jira.groovy.jql.relations.SubtasksOf.getValues() is applicable for argument types: (com.atlassian.jira.jql.query.QueryCreationContextImpl, com.atlassian.query.operand.FunctionOperand, com.atlassian.query.clause.TerminalClauseImpl) values: [com.atlassian.jira.jql.query.QueryCreationContextImpl@b7bd2966, ...] Possible solutions: getIssues(), getClass() at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.unwrap(ScriptBytecodeAdapter.java:56) at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.call(PogoMetaClassSite.java:51) at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:138) at com.onresolve.jira.groovy.jql.ScriptedJqlFunction.getValues(ScriptedJqlFunction.groovy:104) at com.atlassian.jira.jql.operand.FunctionOperandHandler$3.call(FunctionOperandHandler.java:73) at com.atlassian.jira.jql.operand.FunctionOperandHandler$3.call(FunctionOperandHandler.java:69) at com.atlassian.ozymandias.SafePluginPointAccess.call(SafePluginPointAccess.java:187) at com.atlassian.jira.jql.operand.FunctionOperandHandler.getValues(FunctionOperandHandler.java:68) at com.atlassian.jira.jql.operand.FunctionOperandHandler.getValues(FunctionOperandHandler.java:27) at com.atlassian.jira.jql.operand.DefaultJqlOperandResolver.getValues(DefaultJqlOperandResolver.java:100) at com.atlassian.jira.jql.operand.DefaultJqlOperandResolver.getValues(DefaultJqlOperandResolver.java:72) at sun.reflect.GeneratedMethodAccessor1916.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:497) at com.atlassian.plugin.osgi.hostcomponents.impl.DefaultComponentRegistrar$ContextClassLoaderSettingInvocationHandler.invoke(DefaultComponentRegistrar.java:129) at com.sun.proxy.$Proxy28.getValues(Unknown Source) at sun.reflect.GeneratedMethodAccessor1916.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:497) at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:307) at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:58) at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:62) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171) at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131) at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171) at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:56) at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:39) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171) at org.springframework.osgi.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:59) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171) at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131) at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171) at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204) at com.sun.proxy.$Proxy1313.getValues(Unknown Source) at com.atlassian.jira.plugins.issue.create.context.jql.OperandSimplifier$Scoped.visit(OperandSimplifier.scala:25) at com.atlassian.jira.plugins.issue.create.context.jql.OperandSimplifier$Scoped.visit(OperandSimplifier.scala:19) at com.atlassian.query.operand.FunctionOperand.accept(FunctionOperand.java:78) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.visit(ParamsFetcher.scala:36) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.visit(ParamsFetcher.scala:12) at com.atlassian.query.clause.TerminalClauseImpl.accept(TerminalClauseImpl.java:162) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher$$anonfun$flattenClauses$1.apply(ParamsFetcher.scala:25) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher$$anonfun$flattenClauses$1.apply(ParamsFetcher.scala:25) at scala.collection.TraversableLike$$anonfun$map$1.apply(TraversableLike.scala:244) at scala.collection.TraversableLike$$anonfun$map$1.apply(TraversableLike.scala:244) at scala.collection.Iterator$class.foreach(Iterator.scala:727) at scala.collection.AbstractIterator.foreach(Iterator.scala:1157) at scala.collection.IterableLike$class.foreach(IterableLike.scala:72) at scala.collection.AbstractIterable.foreach(Iterable.scala:54) at scala.collection.TraversableLike$class.map(TraversableLike.scala:244) at scala.collection.AbstractTraversable.map(Traversable.scala:105) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.flattenClauses(ParamsFetcher.scala:25) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.visit(ParamsFetcher.scala:21) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.visit(ParamsFetcher.scala:12) at com.atlassian.query.clause.OrClause.accept(OrClause.java:34) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher$$anonfun$flattenClauses$1.apply(ParamsFetcher.scala:25) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher$$anonfun$flattenClauses$1.apply(ParamsFetcher.scala:25) at scala.collection.TraversableLike$$anonfun$map$1.apply(TraversableLike.scala:244) at scala.collection.TraversableLike$$anonfun$map$1.apply(TraversableLike.scala:244) at scala.collection.Iterator$class.foreach(Iterator.scala:727) at scala.collection.AbstractIterator.foreach(Iterator.scala:1157) at scala.collection.IterableLike$class.foreach(IterableLike.scala:72) at scala.collection.AbstractIterable.foreach(Iterable.scala:54) at scala.collection.TraversableLike$class.map(TraversableLike.scala:244) at scala.collection.AbstractTraversable.map(Traversable.scala:105) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.flattenClauses(ParamsFetcher.scala:25) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.visit(ParamsFetcher.scala:17) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.visit(ParamsFetcher.scala:12) at com.atlassian.query.clause.AndClause.accept(AndClause.java:34) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher$$anonfun$flattenClauses$1.apply(ParamsFetcher.scala:25) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher$$anonfun$flattenClauses$1.apply(ParamsFetcher.scala:25) at scala.collection.TraversableLike$$anonfun$map$1.apply(TraversableLike.scala:244) at scala.collection.TraversableLike$$anonfun$map$1.apply(TraversableLike.scala:244) at scala.collection.Iterator$class.foreach(Iterator.scala:727) at scala.collection.AbstractIterator.foreach(Iterator.scala:1157) at scala.collection.IterableLike$class.foreach(IterableLike.scala:72) at scala.collection.AbstractIterable.foreach(Iterable.scala:54) at scala.collection.TraversableLike$class.map(TraversableLike.scala:244) at scala.collection.AbstractTraversable.map(Traversable.scala:105) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.flattenClauses(ParamsFetcher.scala:25) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.visit(ParamsFetcher.scala:17) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.visit(ParamsFetcher.scala:12) at com.atlassian.query.clause.AndClause.accept(AndClause.java:34) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.findParams(ParamsFetcher.scala:14) at com.atlassian.jira.plugins.issue.create.context.jql.JQLContextResolver.analyze(JQLContextResolver.scala:35) at com.atlassian.jira.plugins.issue.create.context.jql.JQLContextResolver.analyze(JQLContextResolver.scala:24) at com.atlassian.jira.plugins.issue.create.rest.BootstrapHelper.getContextForInputValues(BootstrapHelper.scala:19) at com.atlassian.jira.plugins.issue.create.rest.BootstrapHelper.prepareInlineCreateBootstrap(BootstrapHelper.scala:40) at com.atlassian.jira.plugins.issue.create.rest.JQLContextResource.bootstrapInlineCreate(JQLContextResource.scala:43) at sun.reflect.GeneratedMethodAccessor2004.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:497) at com.atlassian.plugins.rest.common.interceptor.impl.DispatchProviderHelper$ResponseOutInvoker$1.invoke(DispatchProviderHelper.java:234) at com.atlassian.plugins.rest.common.interceptor.impl.DispatchProviderHelper$1.intercept(DispatchProviderHelper.java:100) at com.atlassian.plugins.rest.common.interceptor.impl.DefaultMethodInvocation.invoke(DefaultMethodInvocation.java:61) at com.atlassian.plugins.rest.common.expand.interceptor.ExpandInterceptor.intercept(ExpandInterceptor.java:38) at com.atlassian.plugins.rest.common.interceptor.impl.DefaultMethodInvocation.invoke(DefaultMethodInvocation.java:61) at com.atlassian.plugins.rest.common.interceptor.impl.DispatchProviderHelper.invokeMethodWithInterceptors(DispatchProviderHelper.java:132) at com.atlassian.plugins.rest.common.interceptor.impl.DispatchProviderHelper$ResponseOutInvoker._dispatch(DispatchProviderHelper.java:230) at com.sun.jersey.server.impl.model.method.dispatch.ResourceJavaMethodDispatcher.dispatch(ResourceJavaMethodDispatcher.java:75) at com.sun.jersey.server.impl.uri.rules.HttpMethodRule.accept(HttpMethodRule.java:288) at com.sun.jersey.server.impl.uri.rules.RightHandPathRule.accept(RightHandPathRule.java:147) at com.sun.jersey.server.impl.uri.rules.ResourceClassRule.accept(ResourceClassRule.java:108) at com.sun.jersey.server.impl.uri.rules.RightHandPathRule.accept(RightHandPathRule.java:147) at com.sun.jersey.server.impl.uri.rules.RootResourceClassesRule.accept(RootResourceClassesRule.java:84) at com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1469) at com.sun.jersey.server.impl.application.WebApplicationImpl._handleRequest(WebApplicationImpl.java:1400) at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1349) at com.sun.jersey.server.impl.application.WebApplicationImpl.handleRequest(WebApplicationImpl.java:1339) at com.sun.jersey.spi.container.servlet.WebComponent.service(WebComponent.java:416) at com.sun.jersey.spi.container.servlet.ServletContainer.service(ServletContainer.java:537) at com.atlassian.plugins.rest.module.RestDelegatingServletFilter$JerseyOsgiServletContainer.doFilter(RestDelegatingServletFilter.java:178) at com.sun.jersey.spi.container.servlet.ServletContainer.doFilter(ServletContainer.java:795) at com.atlassian.plugins.rest.module.RestDelegatingServletFilter.doFilter(RestDelegatingServletFilter.java:73) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.plugins.rest.module.servlet.RestServletUtilsUpdaterFilter.doFilterInternal(RestServletUtilsUpdaterFilter.java:26) at com.atlassian.plugins.rest.module.servlet.RestServletUtilsUpdaterFilter.doFilter(RestServletUtilsUpdaterFilter.java:40) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.mywork.client.filter.ServingRequestsFilter.doFilter(ServingRequestsFilter.java:37) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.plugins.cors.CorsFilter.doFilter(CorsFilter.java:65) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFixupFilter.doFilter(PrettyUrlsSiteMeshFixupFilter.java:36) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:60) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:92) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:56) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:36) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(AccessLogFilter.java:106) at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(AccessLogFilter.java:90) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(XsrfTokenAdditionRequestFilter.java:54) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:87) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:239) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:100) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:172) at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:79) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.plugins.rest.module.servlet.RestSeraphFilter.doFilter(RestSeraphFilter.java:40) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176) at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145) at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92) at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:394) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:88) at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:59) at com.atlassian.jira.web.filters.gzip.JiraGzipFilter.doFilter(JiraGzipFilter.java:55) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.analytics.client.filter.JiraAnalyticsFilter.doFilter(JiraAnalyticsFilter.java:40) at com.atlassian.analytics.client.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:32) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at net.bull.javamelody.MonitoringFilter.doFilter(MonitoringFilter.java:198) at net.bull.javamelody.MonitoringFilter.doFilter(MonitoringFilter.java:176) at net.bull.javamelody.PluginMonitoringFilter.doFilter(PluginMonitoringFilter.java:85) at net.bull.javamelody.JiraMonitoringFilter.doFilter(JiraMonitoringFilter.java:104) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:87) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:45) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:79) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.jira.web.filters.MultipartBoundaryCheckFilter.doFilter(MultipartBoundaryCheckFilter.java:41) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:87) at com.atlassian.jira.web.filters.JiraFirstFilter.doFilter(JiraFirstFilter.java:60) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408) at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1070) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:611) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:314) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Thread.java:745)
JamieA
April 30, 2015
Looking for a plugin at least partly written in scala... are you using JIRA service desk?
Chris Solgat
April 30, 2015
I'm not. Not sure about Jason.
Jason Smith April 30, 2015
We're not using JSD either.
JamieA
May 1, 2015
Is the rest of your stack trace the same as Chris's? Can you post the entire stack trace somewhere? thanks.
JamieA
May 1, 2015
Until I know where this issue originates it's difficult to track it down: https://answers.atlassian.com/questions/15290084/which-plugins-supplies-this-code . Do you have any non-standard atlassian labs plugins?
Jason Smith May 1, 2015
Here it is: 2015-05-01 11:02:26,252 ajp-bio-8009-exec-32675 WARN a.pi 662x5143631x6 18f6935 108.171.132.188 /secure/RapidBoard.jspa [com.atlassian.ozymandias.SafePluginPointAccess] Unable to run plugin code because of 'groovy.lang.MissingMethodException - No signature of method: com.onresolve.jira.groovy.jql.HasSubtasks.getValues() is applicable for argument types: (com.atlassian.jira.jql.query.QueryCreationContextImpl, com.atlassian.query.operand.FunctionOperand, com.atlassian.query.clause.TerminalClauseImpl) values: [com.atlassian.jira.jql.query.QueryCreationContextImpl@a842c126, ...] Possible solutions: getIssues(), getClass()'. 2015-05-01 11:02:26,252 ajp-bio-8009-exec-32675 DEBUG a.pi 662x5143631x6 18f6935 108.171.132.188 /secure/RapidBoard.jspa [com.atlassian.ozymandias.SafePluginPointAccess] Unable to run plugin code because of 'groovy.lang.MissingMethodException - No signature of method: com.onresolve.jira.groovy.jql.HasSubtasks.getValues() is applicable for argument types: (com.atlassian.jira.jql.query.QueryCreationContextImpl, com.atlassian.query.operand.FunctionOperand, com.atlassian.query.clause.TerminalClauseImpl) values: [com.atlassian.jira.jql.query.QueryCreationContextImpl@a842c126, ...] Possible solutions: getIssues(), getClass()'. groovy.lang.MissingMethodException: No signature of method: com.onresolve.jira.groovy.jql.HasSubtasks.getValues() is applicable for argument types: (com.atlassian.jira.jql.query.QueryCreationContextImpl, com.atlassian.query.operand.FunctionOperand, com.atlassian.query.clause.TerminalClauseImpl) values: [com.atlassian.jira.jql.query.QueryCreationContextImpl@a842c126, ...] Possible solutions: getIssues(), getClass() at org.codehaus.groovy.runtime.ScriptBytecodeAdapter.unwrap(ScriptBytecodeAdapter.java:56) at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.call(PogoMetaClassSite.java:51) at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:45) at com.onresolve.jira.groovy.jql.entitymatch.AbstractEntityMatch$getValues.call(Unknown Source) at com.onresolve.jira.groovy.jql.ScriptedJqlFunction.getValues(ScriptedJqlFunction.groovy:104) at com.atlassian.jira.jql.operand.FunctionOperandHandler$3.call(FunctionOperandHandler.java:73) at com.atlassian.jira.jql.operand.FunctionOperandHandler$3.call(FunctionOperandHandler.java:69) at com.atlassian.ozymandias.SafePluginPointAccess.call(SafePluginPointAccess.java:187) at com.atlassian.jira.jql.operand.FunctionOperandHandler.getValues(FunctionOperandHandler.java:68) at com.atlassian.jira.jql.operand.FunctionOperandHandler.getValues(FunctionOperandHandler.java:27) at com.atlassian.jira.jql.operand.DefaultJqlOperandResolver.getValues(DefaultJqlOperandResolver.java:101) at com.atlassian.jira.jql.operand.DefaultJqlOperandResolver.getValues(DefaultJqlOperandResolver.java:73) at sun.reflect.GeneratedMethodAccessor883.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at com.atlassian.plugin.osgi.hostcomponents.impl.DefaultComponentRegistrar$ContextClassLoaderSettingInvocationHandler.invoke(DefaultComponentRegistrar.java:134) at com.sun.proxy.$Proxy524.getValues(Unknown Source) at sun.reflect.GeneratedMethodAccessor883.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:307) at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:58) at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:62) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171) at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131) at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171) at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:56) at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:39) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171) at org.springframework.osgi.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:59) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171) at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131) at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171) at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204) at com.sun.proxy.$Proxy1131.getValues(Unknown Source) at com.atlassian.jira.plugins.issue.create.context.jql.OperandSimplifier$Scoped.visit(OperandSimplifier.scala:25) at com.atlassian.jira.plugins.issue.create.context.jql.OperandSimplifier$Scoped.visit(OperandSimplifier.scala:19) at com.atlassian.query.operand.FunctionOperand.accept(FunctionOperand.java:78) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.visit(ParamsFetcher.scala:36) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.visit(ParamsFetcher.scala:12) at com.atlassian.query.clause.TerminalClauseImpl.accept(TerminalClauseImpl.java:162) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher$$anonfun$flattenClauses$1.apply(ParamsFetcher.scala:25) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher$$anonfun$flattenClauses$1.apply(ParamsFetcher.scala:25) at scala.collection.TraversableLike$$anonfun$map$1.apply(TraversableLike.scala:244) at scala.collection.TraversableLike$$anonfun$map$1.apply(TraversableLike.scala:244) at scala.collection.Iterator$class.foreach(Iterator.scala:727) at scala.collection.AbstractIterator.foreach(Iterator.scala:1157) at scala.collection.IterableLike$class.foreach(IterableLike.scala:72) at scala.collection.AbstractIterable.foreach(Iterable.scala:54) at scala.collection.TraversableLike$class.map(TraversableLike.scala:244) at scala.collection.AbstractTraversable.map(Traversable.scala:105) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.flattenClauses(ParamsFetcher.scala:25) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.visit(ParamsFetcher.scala:17) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.visit(ParamsFetcher.scala:12) at com.atlassian.query.clause.AndClause.accept(AndClause.java:34) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher$$anonfun$flattenClauses$1.apply(ParamsFetcher.scala:25) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher$$anonfun$flattenClauses$1.apply(ParamsFetcher.scala:25) at scala.collection.TraversableLike$$anonfun$map$1.apply(TraversableLike.scala:244) at scala.collection.TraversableLike$$anonfun$map$1.apply(TraversableLike.scala:244) at scala.collection.Iterator$class.foreach(Iterator.scala:727) at scala.collection.AbstractIterator.foreach(Iterator.scala:1157) at scala.collection.IterableLike$class.foreach(IterableLike.scala:72) at scala.collection.AbstractIterable.foreach(Iterable.scala:54) at scala.collection.TraversableLike$class.map(TraversableLike.scala:244) at scala.collection.AbstractTraversable.map(Traversable.scala:105) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.flattenClauses(ParamsFetcher.scala:25) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.visit(ParamsFetcher.scala:21) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.visit(ParamsFetcher.scala:12) at com.atlassian.query.clause.OrClause.accept(OrClause.java:34) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher$$anonfun$flattenClauses$1.apply(ParamsFetcher.scala:25) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher$$anonfun$flattenClauses$1.apply(ParamsFetcher.scala:25) at scala.collection.TraversableLike$$anonfun$map$1.apply(TraversableLike.scala:244) at scala.collection.TraversableLike$$anonfun$map$1.apply(TraversableLike.scala:244) at scala.collection.Iterator$class.foreach(Iterator.scala:727) at scala.collection.AbstractIterator.foreach(Iterator.scala:1157) at scala.collection.IterableLike$class.foreach(IterableLike.scala:72) at scala.collection.AbstractIterable.foreach(Iterable.scala:54) at scala.collection.TraversableLike$class.map(TraversableLike.scala:244) at scala.collection.AbstractTraversable.map(Traversable.scala:105) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.flattenClauses(ParamsFetcher.scala:25) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.visit(ParamsFetcher.scala:17) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.visit(ParamsFetcher.scala:12) at com.atlassian.query.clause.AndClause.accept(AndClause.java:34) at com.atlassian.jira.plugins.issue.create.context.jql.ParamsFetcher.findParams(ParamsFetcher.scala:14) at com.atlassian.jira.plugins.issue.create.context.jql.JQLContextResolver.analyze(JQLContextResolver.scala:41) at com.atlassian.jira.plugins.issue.create.rest.ContextResolutionHelper.possibleValuesForClause(ContextResolutionHelper.scala:43) at com.atlassian.jira.plugins.issue.create.rest.ContextResolutionHelper.possibleValuesForIssueInput(ContextResolutionHelper.scala:49) at com.atlassian.greenhopper.service.query.FieldPossibleValuesAdapterImpl.possibleValuesForIssueInput(FieldPossibleValuesAdapterImpl.java:21) at com.atlassian.greenhopper.service.query.FieldPossibleValues$1.apply(FieldPossibleValues.java:38) at com.atlassian.greenhopper.service.query.FieldPossibleValues$1.apply(FieldPossibleValues.java:34) at com.atlassian.fugue.Option.map(Option.java:276) at com.atlassian.greenhopper.service.query.FieldPossibleValues.getProjectIdsForQuery(FieldPossibleValues.java:33) at com.atlassian.greenhopper.service.query.QueryToProjectMapper$RapidViewCacheLoader.load(QueryToProjectMapper.java:137) at com.atlassian.greenhopper.service.query.QueryToProjectMapper$RapidViewCacheLoader.load(QueryToProjectMapper.java:132) at com.atlassian.cache.compat.delegate.DelegatingCacheLoader.load(DelegatingCacheLoader.java:23) at com.atlassian.cache.memory.MemoryCacheManager$3$1.load(MemoryCacheManager.java:130) at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3573) at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2350) at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2313) at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2228) at com.google.common.cache.LocalCache.get(LocalCache.java:3970) at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:3974) at com.google.common.cache.LocalCache$LocalManualCache.get(LocalCache.java:4834) at com.atlassian.cache.memory.DelegatingCache$DelegatingLoadingCache.get(DelegatingCache.java:300) at com.atlassian.cache.compat.delegate.DelegatingCache.get(DelegatingCache.java:37) at com.atlassian.greenhopper.service.query.QueryToProjectMapper.getProjectContextIdsForQuery(QueryToProjectMapper.java:76) at com.atlassian.greenhopper.service.query.QueryServiceImpl.getProjectsForRapidView(QueryServiceImpl.java:114) at com.atlassian.greenhopper.service.query.QueryServiceImpl.getExplicitProjectsForRapidViewFilterQuery(QueryServiceImpl.java:101) at com.atlassian.greenhopper.service.rapid.ProjectRapidViewServiceImpl.findRapidViewsByProject(ProjectRapidViewServiceImpl.java:53) at com.atlassian.greenhopper.web.sidebar.BoardSidebarRenderer.projectIsPartOfRapidViewFilter(BoardSidebarRenderer.java:110) at com.atlassian.greenhopper.web.sidebar.BoardSidebarRenderer.shouldShowProjectSidebar(BoardSidebarRenderer.java:103) at com.atlassian.greenhopper.web.sidebar.BoardSidebarRenderer.shouldShowSidebar(BoardSidebarRenderer.java:96) at com.atlassian.greenhopper.web.sidebar.BoardSidebarRenderer.shouldShowSidebar(BoardSidebarRenderer.java:83) at com.atlassian.greenhopper.web.rapid.RapidBoardAction.shouldShowSidebar(RapidBoardAction.java:235) at sun.reflect.GeneratedMethodAccessor1680.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at org.apache.velocity.util.introspection.UberspectImpl$VelMethodImpl.doInvoke(UberspectImpl.java:385) at org.apache.velocity.util.introspection.UberspectImpl$VelMethodImpl.invoke(UberspectImpl.java:374) at com.atlassian.velocity.htmlsafe.introspection.UnboxingMethod.invoke(UnboxingMethod.java:30) at org.apache.velocity.runtime.parser.node.ASTMethod.execute(ASTMethod.java:270) at org.apache.velocity.runtime.parser.node.ASTReference.execute(ASTReference.java:262) at org.apache.velocity.runtime.parser.node.ASTReference.evaluate(ASTReference.java:470) at org.apache.velocity.runtime.parser.node.ASTExpression.evaluate(ASTExpression.java:62) at org.apache.velocity.runtime.parser.node.ASTIfStatement.render(ASTIfStatement.java:85) at org.apache.velocity.runtime.parser.node.SimpleNode.render(SimpleNode.java:336) at org.apache.velocity.Template.merge(Template.java:328) at org.apache.velocity.Template.merge(Template.java:235) at org.apache.velocity.app.VelocityEngine.mergeTemplate(VelocityEngine.java:381) at com.atlassian.velocity.DefaultVelocityManager.writeEncodedBodyImpl(DefaultVelocityManager.java:117) at com.atlassian.velocity.DefaultVelocityManager.writeEncodedBody(DefaultVelocityManager.java:97) at com.atlassian.jira.template.velocity.DefaultVelocityTemplatingEngine$DefaultRenderRequest.toWriterImpl(DefaultVelocityTemplatingEngine.java:146) at com.atlassian.jira.template.velocity.DefaultVelocityTemplatingEngine$DefaultRenderRequest.asHtml(DefaultVelocityTemplatingEngine.java:134) at com.atlassian.jira.web.dispatcher.JiraVelocityViewDispatcher.dispatch(JiraVelocityViewDispatcher.java:50) at com.atlassian.jira.web.dispatcher.JiraWebworkViewDispatcher.dispatchViaVelocityView(JiraWebworkViewDispatcher.java:111) at com.atlassian.jira.web.dispatcher.JiraWebworkViewDispatcher.dispatchView(JiraWebworkViewDispatcher.java:70) at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.service(JiraWebworkActionDispatcher.java:204) at javax.servlet.http.HttpServlet.service(HttpServlet.java:727) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:87) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.jira.web.filters.XContentTypeOptionsNoSniffFilter.doFilter(XContentTypeOptionsNoSniffFilter.java:22) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.jira.tzdetect.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:40) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.jira.baseurl.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:38) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.jira.onboarding.postsetup.ui.PostSetupAnnouncementsFilter.doFilter(PostSetupAnnouncementsFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.mywork.client.filter.ServingRequestsFilter.doFilter(ServingRequestsFilter.java:37) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFixupFilter.doFilter(PrettyUrlsSiteMeshFixupFilter.java:36) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsDispatcherFilter.doFilter(PrettyUrlsDispatcherFilter.java:60) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsSiteMeshFilter.doFilter(PrettyUrlsSiteMeshFilter.java:92) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsMatcherFilter.doFilter(PrettyUrlsMatcherFilter.java:56) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.labs.botkiller.BotKillerFilter.doFilter(BotKillerFilter.java:36) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(AccessLogFilter.java:107) at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(AccessLogFilter.java:91) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(XsrfTokenAdditionRequestFilter.java:54) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:181) at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:85) at com.atlassian.jira.web.filters.SitemeshPageFilter.doFilter(SitemeshPageFilter.java:124) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.jira.web.filters.pagebuilder.PageBuilderFilter.doFilter(PageBuilderFilter.java:90) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.jira.web.filters.CommittedResponseHtmlErrorRecoveryFilter.doFilter(CommittedResponseHtmlErrorRecoveryFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:239) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:100) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:172) at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:79) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99) at com.atlassian.jira.web.filters.JIRAProfilingFilter.doFilter(JIRAProfilingFilter.java:19) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.tuckey.web.filters.urlrewrite.RuleChain.handleRewrite(RuleChain.java:176) at org.tuckey.web.filters.urlrewrite.RuleChain.doRules(RuleChain.java:145) at org.tuckey.web.filters.urlrewrite.UrlRewriter.processRequest(UrlRewriter.java:92) at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:394) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:82) at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:59) at com.atlassian.jira.web.filters.gzip.JiraGzipFilter.doFilter(JiraGzipFilter.java:56) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:70) at com.atlassian.prettyurls.filter.PrettyUrlsCombinedMatchDispatcherFilter.doFilter(PrettyUrlsCombinedMatchDispatcherFilter.java:61) at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:78) at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77) at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:87) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:49) at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:79) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.jira.web.filters.MultipartBoundaryCheckFilter.doFilter(MultipartBoundaryCheckFilter.java:41) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:87) at com.atlassian.jira.web.filters.JiraFirstFilter.doFilter(JiraFirstFilter.java:61) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:220) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:122) at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:501) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116) at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:950) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:408) at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:190) at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:611) at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:314) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Thread.java:745)
Timothy Harris
Actually I am running into the same problem. I had a scripted JQL function which was working fine. Suddenly it complains that there is no signature for method getIssues(subquery), where subquery is just a string.
Uncaught exception thrown by REST service: No signature of method: com.onresolve.jira.groovy.jql.dsvBadEpicL
inks.getIssues() is applicable for argument types: (java.lang.String) values: [project = CP]
Possible solutions: getIssues(), getIssues(java.lang.String, com.atlassian.jira.user.ApplicationUser), getIssues(java.lang.String, com.atlassian.jira.user.ApplicationUser, org.apache.lucene.search.Query), setIssues(java.util.List), getIssues(java.lang.String, com.atlassi
an.jira.user.ApplicationUser, org.apache.lucene.search.Query, com.onresolve.jira.groovy.jql.FilterCollector)
Timothy Harris
I actually had to change the script to use the second method form. The one with the applicationUser as a parameter. Why this change I do not know. I did not upgrade anything. I changed my script. Disabled and re-enabled script runner and walla. it worked.
JamieA
May 1, 2015
This was changed in Oct last year to support usage when no users are logged in: https://jamieechlin.atlassian.net/browse/GRV-529 Sorry about that. I don't think it's the same issue as the OP's though.
JamieA
May 1, 2015
It was a change in 3.0.7, so it stopping working probably coincided with an upgrade of SR.
Timothy Harris
Ah, OK. One of the other guys probably did an upgrade. Thanks for the information!
Help us plant more trees
