×Hi
Our team have regular tasks that need to be carried out every month with set deadlines.
the deadlines are dependent on business days. E.g. Task A is due on T+4 Business Days every month.
Can we use JIRA to effectively handle rolling deadlines for such recurring tasks.
How can i use a board to do this effecitvely?
Hi @Saad ,
In OOTB Jire there is not much you can do to set up and recurring task and add a dynamic deadline date that is based on business days. Not sure how boards can be used here also.. You would need to somehow connect this with status..
From what I know the Scheduler plugin should be able to fit 100% with you requirements where you can set dynamic due dates when setting up a recurring task every month
https://psc-software.atlassian.net/wiki/spaces/SCHED/pages/2528765/Setting+a+Due+Date+Field+5.x
There are also other plugins that can automate things (like Jira Automation Plugin) but this is something that you need to explore and check if it is good for your process.
