Hello @[deleted] ,
Step1: Goto Reports --> Sprint Report --> Get the sprint id from the URL (1000)
https://yourinstanceurl/jira/secure/RapidBoard.jspa?rapidView=955&projectKey=PROJJ&view=reporting&chart=sprintRetrospective&sprint=1000
Step2: From sprint report click on "View in Issue navigator"
Step3: Click on ... --> Tools --> Bulk Change --> Choose the issues you like to change --> Edit Issues --> Change Sprint --> Add the sprint id from above url (1000) --> Scroll down (uncheck Send mail for this update) --> Next --> Confirm
Note: Make sure "Sprint" Field is enabled on your edit screen
I tried this approach on Aug 21, 2024 and it works.
but somehow this approach is not working now.
Does anyone have another solution to achieve this goal with another approach?
