×Goog morning,
we need to change the server in which we have installed JIRA (from Win2000 to Win2008).
For the db everithing can be done by using a dump of the db, but for the attachments that are sotred in a folder of the server what we have to do?
We just have to move the files under the same foled in the new server?
Stefania
Stefania,
I do this very thing regularly to get a snapshot of my production system onto a development system and it works reliably every time even when moving from one database server to another.
I really don't recommend the DB dump method in the JIRA case if you can avoid it. The XML variant i suggest here seems to be more consistent and (most important to me) simple.
mike
Hello Stefania,
Yes, you'll need to move your attachments to the new $jira_home, however I recommend you to ensure you're following the guidelines described here to have a smooth migration.
-- Arthur Gonçalves
