We currently have few custom fields which we want to remove eventually. So, before we remove them we want to move the data in these custom fields to a new custom field or any system field like Description.
If below are the custom fields -
Source Server = ABC
Target Server = XYZ
I want the below change -
Description = Source Server = ABC
Target Server = XYZ
So, I want the custom field names and their values appearing in the Description field or any other custom field say Service Request Details.
We have 300+ issues in a project and we want to make this change to the existing issues. I have weighed options to create a post-function but I believe it works only with new issues created. Also, an export and import but we have to make modifications in the spreadsheet I believe. Also, doing an export and import will change the issue numbers right?
Please let me know the best way to do this.
You would need an add-on for it like Power Scripts or Adaptivist ScriptRunner.
If you have Power Scripts add-on then your post-function would look like this
description = "Source Server = " + #{Source Server} + "Target Server = " + #{Target Server}
You could also write a job based on the script above and run it for the old issues.
