Hi All
I am moving our instance of JIRA to a more powerful machine. To do so I am currently installing the same software set up we currently use so that I can then copy the HOME and Install directories over.
The bit I am puzzling over is creating a new JIRA db on the new machine into which the db can be imported. For which i will use something like:
GRANT SELECT,INSERT,UPDATE,DELETE,CREATE,DROP,ALTER,INDEX on JIRADB.* TO 'jiradbuser'@'localhost' IDENTIFIED BY 'password';
flush privileges;
The bit I am wondering about is do "jiradbuser" and "password" have to match that when the original db was set up? If so is there anyway i can retrieve this as at the moment I cannot remember/locate them.
I looked at
https://confluence.atlassian.com/display/JIRAKB/JIRA+Unable+to+Update+MySQL
Which seems to imply they can be found in
<jira-install>/conf/server.xml
But I cannot see the information there.
Thanks for you help
Nick
Hi Nick,
Just a question: Why don't you simply install a new JIRA instance and use the restore backup option to import all data? It would simply be the following steps:
Best regards,
Peter
Hi Peter
I thought thats what I have done..
1. Exported data
2. Installed MYSQL on new machine; created new empty database
3. Installed JIRA
4. Connected JIRA and imported the exported data
5. Over wrote new JIRA install and home directories with previous from spource machine
6. Try to connect and then get issue (described above)
HTTP Status 500 - com.opensymphony.module.propertyset.PropertyImplementationException: Unable to esablish a connection with the database. (Access denied for user 'jiradbuser'@'localhost' (using password: NO))
Go to you myssql and execute the following commands:
GRANT SELECT,INSERT,UPDATE,DELETE,CREATE,DROP,ALTER,INDEX on JIRADB.* TO 'jiradbuser'@'*' IDENTIFIED BY 'password';
flush privileges;
then update your dbconfig.xml to use the password.
restart JIRA, try again.
I thought you exported the database using the mysql tools, not the Jira tools.
Best regards,
Peter
You said earlier that the import timed out, which could explain some of the problems you're getting.
Not the "unable to establish connection" message - that's happening before you hit any potentially damaged data.
As Peter says, you really should be using the database's own tools to get a full clean copy and import that (unless you're changing database or upgrading really old Jiras)
Hi Peter
Many thanks.. I no longer get the error previously mentioned... now I get nothing. it looks like the connection is made.. the browser tab has the JIRA mini icon but no web page is displayed.
The config tool says the db connects succesfully
I double checked the dbconfig.xml file... that has the password
tried rebooting.. no change
Beginning to think I need to start over....
Nick
Hi Nick,
Is there any mention of an error in your atlassian-jira.log file?
Or in the catalina.out?
Best regards,
Peter
The Catalina logs shows:
Jun 24, 2014 1:50:57 PM org.apache.catalina.startup.TldConfig tldScanWebXml WARNING: Failed to process TLD with path [jiratags] and URI [/WEB-INF/tld/atlassian-jira-tags.tld] java.net.MalformedURLException at java.net.URL.<init>(Unknown Source) at java.net.URL.<init>(Unknown Source) at java.net.URL.<init>(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLEntityManager.setupCurrentEntity(Unknown Source) at com.sun.org.apache.xerces.internal.impl.XMLVersionDetector.determineDocVersion(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source) at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source) at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source) at org.apache.tomcat.util.digester.Digester.parse(Digester.java:1537) at org.apache.catalina.startup.TldConfig.tldScanStream(TldConfig.java:515) at org.apache.catalina.startup.TldConfig.tldScanWebXml(TldConfig.java:328) at org.apache.catalina.startup.TldConfig.execute(TldConfig.java:243) at org.apache.catalina.startup.TldConfig.lifecycleEvent(TldConfig.java:540)
Hi Peter
I just used MySQLWOrkbench to do an export and then import. That all seemed to go OK
on using a browser I am seeing:
HTTP Status 500 - /views/setup-db.jsp (line: 1, column: 38) File "/WEB-INF/tld/webwork.tld" not found
type Exception report
message /views/setup-db.jsp (line: 1, column: 38) File "/WEB-INF/tld/webwork.tld" not found
description The server encountered an internal error (/views/setup-db.jsp (line: 1, column: 38) File "/WEB-INF/tld/webwork.tld" not found) that prevented it from fulfilling this request.
exception
org.apache.jasper.JasperException: /views/setup-db.jsp (line: 1, column: 38) File "/WEB-INF/tld/webwork.tld" not found org.apache.jasper.compiler.DefaultErrorHandler.jspError(DefaultErrorHandler.java:42) org.apache.jasper.compiler.ErrorDispatcher.dispatch(ErrorDispatcher.java:408) org.apache.jasper.compiler.ErrorDispatcher.jspError(ErrorDispatcher.java:133) org.apache.jasper.compiler.TagLibraryInfoImpl.<init>(TagLibraryInfoImpl.java:166) org.apache.jasper.compiler.Parser.parseTaglibDirective(Parser.java:410) org.apache.jasper.compiler.Parser.parseDirective(Parser.java:475)
Did you also copy the install directory or is this a newly installed JIRA instance?
You seem to be missing some files in your installation directory.
Find those files (webwork.tld) and place them in the correct location, the try again.
Best regards,
Peter
Hi Peter
Finally success. Very odd those files were missing... cant explain that.
So final solution was to recopy the INSTALL and HOME dirs
and export and import the databases using MySQL Workbench
Now to do some validation. Thanks to all those that helped out.
Nick
>mmm now thats very odd and I suspect not good practice.
Well you should take that up with who did it! I'd never recommend it either!
>In someways my original question stands.. do the username & password I set here HAVE to match those that were set in the original database.
Yes, if you want to use the same database unchanged
>If not then I can create this new DB with user and password to anything.
If you import the whole database including all its settings, then you'll inherit username/password. Absolutley no reason you can't simply change it and use what you like.
Hi All sorry for the quiet period... Only just back on trying to move JIRA
OK: So I backed up the HOME and INSTALL Directories after exporting the data.
I transferred these to the new machine and imported the data. (first concern is that I got a server timed out message after 35 mins. When I started a browser things seemed to be there...
Anyway I then pressed on with copying over the HOME and INSTALL Directories.
The JIRA service seems to start OK (using services.msc on windows)
But when I fire up the browser I now get:
Then I remembered the original db didnt have a password and on this one I had set one. So I edited the dbconfig to reflect this.
Again restarting the service and opening a browser I get the same message... I am sure this is linked to what you wrote nic.. but I am at a loss
Any offers?
Can you try connection to DB using username and password using configuration utility? Here are steps from documentation.
config.bat
in the bin
sub-directory of the JIRA Installation Directory.config.sh
in the bin
sub-directory of theJIRA Installation Directory.You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
That shows you can now get into the database using whatever credentials you used for that test.
Next step would be to try reconnecting the Jira instance.
However, my next question is why you're trying to use xml? If you're not changing database type, or trying to upgrade an old version of Jira, you really should just take a copy of the old data and connect Jira to it.
Hi Nic,
Perhaps I am being dense. I read what you wrote nic but I dont understand it. I mean I just looked on the JIRA website about how to move servers and tried to do what it said.. namely copy and replace the installation and home dirs after importing the exported data. When you write:
"you really should just take a copy of the old data and connect Jira to it."
what do you mean?
Jira is made up of several components (I won't bore you with details of these), one of which is the data that represents your issues, projects, most of the configuration and so-on.
This data lives in a database, which is completely separate to Jira
If you want to "move" a Jira installation, you can pick up all the other components and move them to a new place, and point them at the old database. You don't need to touch the database at all if you are simply moving the appliction to a new server.
There is often a slight complication - if you are running the database server on the same server as Jira and you decide to move that as well, then you've got the additional task of moving the database stuff, but again, if you're just moving it, you don't need to do anything other than make the database work as it did before.
You only need the export/import if you are changing the underlying database (e.g. Oracle -> MySQL) or upgrading older versions of Jira (newer versions from 4.something, it's recommended to use the automatic upgrade function)
Thanks Nic...I am moving both the database and JIRA server to a new VM... that is why I have moved JIRA... but I thought I had to set up MySQL again and that included doing an export and import of the data into the newly setup database.
You wrote: then you've got the additional task of moving the database stuff, but again, if you're just moving it, you don't need to do anything other than make the database work as it did before.
Are you saying I can do a fresh install of MYSQL and then overwrite it with the old installation?
Hey there Nick,
You should be able to find the username and password used to connect to your DB inside the 'dbconfig.xml' file which is in your JIRA Home directory
Hi Joe,
Thanks for the quick reply. in dbconfig.xml I see:
<username>jiradbuser</username>
<password></password>
Does this mean no password Or is it obfuscated?
Nick
That means you've no password set!
Thanks Nic
In someways my original question stands.. do the username & password I set here HAVE to match those that were set in the original database. If not then I can create this new DB with user and password to anything.
Hmm, I don't think that it has to be the same. The username and password is just to create the connection to the database server, I believe. As long as the instance is connected to the database properly, it should work fine.
...Of course, always have a backup in hand :)
Just had a thought..... or doesnt it mater its the same key and its just the total number of licences in use e.g. for a 500 licence.. having 2 server with 250 users on each would work.
No.
The licences is X users on a single server. For two servers, you need two licences.
Indeed, a license is only meant for a single server/instance. If you are running more than one, then you would need a license for each one.
What I can suggest would be, generate a dev or eval license. For now, use the dev/eval license in your newly set up instance. Once everything is confirmed to work fine in the new instance (and all of your users have moved to the new instance), switch the production license into the new instance.
