Use case
SVN is the VCS system. Fisheye and Crucible are used for searching code and reviews.
Team now wants to migrate from SVN to Git and start using Bitbucket.
Question(s)
Hello @Timothy Harris,
For question #1)
Your best option is to stop indexing the SVN repository, but keep it configured in Fisheye, so as to be able to work on existing reviews and to see historic data from it in Jira side, and then start working and committing changes only in the Git repository, which you should let Fisheye keep indexing, and create new reviews only from this Git repository, from now onwards. The SVN repository would just remain there for serving historic data.
For question #2)
If you stop the indexing of that SVN repository in Fisheye you can safely shutdown the SVN server. As Fisheye create local indexes of your repositories, it will continue to serve the information to Jira from its local caches.
I hope this helps!
