Multi Checkboxes design
Samir Freelance
July 12, 2011
How to modify the custom field Multi Checkboxes to be displayed in horizontal ?
Samir Freelance
July 17, 2011
<script language="javascript">
var YOUR_CF_NAME = "check boxes";
AJS.$(document).ready(function(){
for(var i=0; i < AJS.$("fieldset").length; i++) {
if(AJS.$("fieldset:eq(" + i + ") legend span")[0] != null && AJS.$("fieldset:eq(" + i + ") legend span")[0].innerHTML == YOUR_CF_NAME) {
AJS.$("fieldset:eq(" + i + ") div").css('display', 'inline');
AJS.$("fieldset:eq(" + i + ") div").css('float', 'left');
</script>
  • Change the YOUR_CF_NAME value up there to the name of your customfield, as the script is not aware of the name of your custom field, so you need to tell it.
  • You may place it in Administration > Issue Fields > Field Configurations > <your-field-configuration> > Edit (for your check box cutomfield)
thanks for the support
RedPS
January 23, 2020 edited
Hi, sorry for the bump but here's the update one based on my knowledge and skills and using your code as reference.. I've made changes although it is not the best
var YOUR_CF_NAME = "customfield_<customfieldid>";
for(var i=0; i < $("fieldset").length; i++) {
if(i > 0 ) {
$("fieldset:eq(" + i + ") div").css('margin-left', '10px');
Norman Abramovitz
October 22, 2011
I am new to Jira, but I am confused. I am using Jira 4.4.3 and the information about where to put these changes does not make any sense to me. When I look at the html source file through the browser, the css comes from a file named batch.css. The veiw-multiselect.vm does not seem to match source html structure. There is no class shorten in the source html and the id does not match either.
The directions claims we can add javscript through the adminstration interface, but there nothing I can find in the field configuration area where I can add javascript.
I did find the aui-overrides.css file, but I cannot find any information about how that file information gets into batch.css.
What is the real scoop here?
Samir Freelance
July 13, 2011
I mean Multi Checkboxes
Choose multiple values using checkboxes.
Nic Brough -Adaptavist-
July 12, 2011
You'll need to amend the view-multiselect.vm file and restart Jira.
Samir Freelance
July 13, 2011
#if ($value)
<div class="shorten" id="${customField.id}-field">
#foreach ($singleValue in $value)
<span>$!singleValue.toString()#if ($velocityCount != $value.size())</span>,#end
#end
</div>
#end
what should i modify in order to be displayed horizontal
Penny Wyatt (On Leave to July 2021)
July 13, 2011
Changing the div to a span might do it, though I haven't tried - since a div starts a new line and a span doesn't.
Samir Freelance
July 13, 2011
Samir Freelance
July 13, 2011
NO CHANGE also i delete work folder and restarted the service but the combobox sill in vertical
#if ($value)
<span>
#end
</span>
#end
