Multi-Language Issue
Rajkumar September 25, 2024
Hi Team,
We are facing weird issue which is, apart from English, when any other languages pasted in Description, the description doesn't save the languages correctly instead it throws some weird symbols.
Raj
Florian Bonniec
Hi @Rajkumar
It's probably related to the encoding option selected that is not compatible with the characters.
Regards
Rajkumar October 4, 2024
Thank you i was able to fix the issue based on your comments
