HI,
we have installed the Multi Level Select in your Jira 4.0 Installation. It seems to work on creation of issues but if we try to create a search on this custom field we got a exeption ....
HTTP Status 404 - Could not execute action [IssueNavigator]:com.atlassian.jira.issue.customfields
Have anybody an idea who to solve the problem?
regards
Steffi
it seems to work with the advanced search. THX
is there a possibility to configute/install the plugin so that the simple search can be used?
Reagrds
Steffi
Have you try to search using JQL? For regular cascade, the normal "IN" operator works for me. So if I have Student - Peter as my values, i can search "field in ("Peter")"
hope that helps
