Multi project management with JIRA
G.S August 25, 2011
Hi guys,
I'm searching for a function or plugin for multi project management with JIRA. Is it possible at all?
Thanks and regards
Björn Frauen June 4, 2013
Hi guys,
multi project management can be done in JIRA basically via five different ways:
* Using GreenHopper Scrum Board: (my favorite)
- Here you can use a single scrum board to show all issues of all your projects including the different project versions and the versions's progress.
- The sprints may be used for the planning. Many of my customers are happy with sprints like: "KW 1-2", "KW-2-3", "February", "March", "Q2", "Q3", "Q4".
- The quick-filters can be used to generate several views.
* Using GreenHopper Kanban Board:
- You can use a Kanban-Board to show all issues with the issuetype "Project". The columns represent the project's status.
* Structure Plugin:
- The structure plugin can be used for multi project management as described here: http://blog.codecentric.de/2012/02/multiprojektmanagement-mit-jira-und-dem-structure-plugin/
* Gantt-Chart Plugins (https://marketplace.atlassian.com/search?q=gantt)
- These plugins use dates of jira issues and versions as well es issue links to create a gantt-chart.
- Unfortunately my experience with these plugins is a lack of usability.
* Confluence TeamCalendar
- You can use Confluence TeamCalendar to show JIRA dates from issues and versions based on a jira filter.
- i.e. you can build a jira filter for all issues of the type project to show their start and end date in TeamCalendar.
- alternativly or in addition you can show the version dates of selected jira projects.
Rick Breidenstein
I believe Portfolio solves this ask.
Link to market place: https://www.atlassian.com/purchase/addon/com.radiantminds.roadmaps-jira
Marcin Geb _SoftwarePlant_
'Multi project management' means these to me:
  • a single - super aggregated progress bar for the whole portfolio (for a CEO)
  • being able to drill the whole thing down to the sub-task level (for a team)
  • no matter which tool you use - roadmaps, boards, risk matrices, Gantt charts, resources - you can change your perspective from the day, to week, to month, to year
Look up 'PPM' on Atlassian Marketplace.
One of the leaders is BigPicture, version 8 in particular ;)
Fig. 1 Portfolio level
Igor Gorbenko
May 30, 2019
I think the issue is not the number of projects but resource management if you have shared resources.
Epicflow plugin helps with that in a multi-project environment.
Herb Chan August 26, 2011
Are you looking to administer multiple projects in JIRA at the same time? I don't think this is possible.
G.S August 28, 2011
That's what I'm searching for, a possibility to manage many projects at the same time, in "1" view. There should be an overwiev:
- all ressources I have
- all ressources in process
- alert system for a disadvantage allocation
Like Mario Schmidt likes this
Radu Dumitriu
August 28, 2011
You are looking for Project Management Software, not Issue Tracking. I think there are some plugins trying to accomplish that in some degree, but they are different, you know ...
G.S August 28, 2011
I searched yet but could not find an adequate. Did I overlook anyone or di you have a tip?
Igor Sereda [ALM Works]
August 26, 2011
Could you please elaborate? JIRA is a project management tool and it supports multiple projects. What exactly are you looking for?
