Does someone out there have a plugin to add a custom field type like a multiple project picker?
Thanks in advance.
Multi Project Picker does your job however if your Jira under v7.13.13.
They are not releasing any more new versions that supporting Jira v8
Hey there, Luana.
Seems like you have to either customize your JIRA instance or even try to develop your own plugin to cater for this. Did a quick search and came across the following link that might be able to help you with this:
Apart from that, you can also consider the following options as well:
Hope this helps.
Warm regards,
Danial
