I have been tasked with setting up service desk, confluence and software to all run on ports 80 and 443. Am I right in thinking that I will need to configure them on separate servers to complete this?
Many thanks
Aaron
Technically, yes, but there are other options.
A port can only be used by one service at a time. So if you run Confluence and Jira on the same server, they will need two different ports to run them on (Service Desk runs inside Jira, it's not a separate service)
When you do that, you end up with urls with ports buried in them, so yes, separate servers are needed.
But, it's easy to relocate these with a proxy. Run Confluence on port 8090, Jira on 8080, and then run a proxy that listens on 80 and 443 and proxies connections to those two ports.
