Related the Groovy Documentation, issueFunction is a customfield that can replace issue in JQL. Also, we use issueFunction in hasComments() instead of issue in hasComments().
Question:
Hi Vincent... this is https://jamieechlin.atlassian.net/browse/GRV-322. I would add you as a watcher but I don't think you have logged in.
issueFunction is a custom field which just exists to use a different method of writing jql functions, as returning a list of QueryLiterals is way too slow.
There should only be one. I don't know yet under what conditions more than one is created... but yes likely it will be on plugin activation. It's safe to delete them all except one. Please could you watch the linked issue, I'll provide more updates there. Also could you comment on that ticket with the relevant version numbers.
