Hi There,
Can someone suggest on the "must have" plugins in an Enterprise projects especially in the BI & Analytics projects driven through Atlassian tools on Cloud?
SK
Hi SK,
I don't think there's an objective answer to your question. It's hard to get an unbiased reply -- there are a lot of app vendors here in the Community (including myself), and each user or consulting partner would have their own set of favorite apps.
I'd suggest you to browse the Atlassian Marketplace. I does a good job of showing which apps are most popular, which are top-grossing (sold the most), which are trending (getting more current attention). It also has a "Staff Picked" category, which contains apps currently pushed by Atlassian. You can filter by the categories that apply to your company or search for a specific keyword.
Additionally, the Marketplace has "collections" pages (links in the footer), which contain best practices and compilations of apps for implementing those.
Hope this helps!
Igor
I couldn't agree more with this answer.
The add-ons you should get for your Atlassian systems should be determined by what you need that the systems don't do off-the-shelf. You might not know what that is until years after you start using Atlassian stuff.
