we have a large JIRA instance (version 5.2.5) in production with :
Hardware Resources:
My JIRA instance run on windows 64 with 32GB of memory system and 16GB of JVM.
Symptoms:
the last days, My JIRA so slow ! Unbearable slowness
My Need:
A hardware recommendation for this type of instance. Especially, RAM, JVM and CPU.
thank you in advance
It already sounds like your hardware is more than adequate to run your JIRA at a decent speed, so I don't think just throwing more resource at it is going to help you a lot.
You need to analyse what is slowing it down and why. I always go back to https://summit.atlassian.com/archives/2013/inside-the-massive-team/the-not-so-dark-art-if-atlassian-performance-tuning - although it's 4 years old now, it's still absolutley valid - you need to understand the problem before you can hope to fix it.
Hi Karim,
look here; https://confluence.atlassian.com/display/JIRA052/JIRA+Requirements
I recommend, that you do an update in the near future. I think newer versions should have a better performance.
