My Jira Application is down
Kurasi Vishnu Priya August 2, 2021
Hi after the jira upgrade to 8.7 from 8.4 and PostgreSQL upgrade to 11.10 .My jira application is not accessible.
please find the logs from Catalina.out , help me to resolve this.
JIRA starting...
2021-08-03 00:26:50,414-0400 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger]
___ Environment _____________________________
JIRA Build : 8.7.0#807000-sha1:03b9519edaeead7975794cb92cbc1a18d2466f89
Build Date : Mon Feb 03 00:00:00 EST 2020
JIRA Installation Type : Standalone
Application Server : Apache Tomcat/8.5.42 - Servlet API 3.1
Java Version : 1.8.0_202 - AdoptOpenJdk
Current Working Directory : /opt/atlassian/jira/bin
Maximum Allowable Memory : 3641MB
Total Memory : 1050MB
Free Memory : 1009MB
Used Memory : 41MB
Memory Pool: Code Cache : Code Cache: init = 33554432(32768K) used = 10511872(10265K) committed = 33554432(32768K) max = 536870912(524288K)
Memory Pool: Metaspace : Metaspace: init = 0(0K) used = 21341920(20841K) committed = 22020096(21504K) max = -1(-1K)
Memory Pool: Compressed Class Space : Compressed Class Space: init = 0(0K) used = 2383200(2327K) committed = 2621440(2560K) max = 1073741824(1048576K)
Memory Pool: PS Eden Space : PS Eden Space: init = 100663296(98304K) used = 18212824(17785K) committed = 803733504(784896K) max = 1371013120(1338880K)
Memory Pool: PS Survivor Space : PS Survivor Space: init = 16777216(16384K) used = 0(0K) committed = 29360128(28672K) max = 29360128(28672K)
Memory Pool: PS Old Gen : PS Old Gen: init = 268435456(262144K) used = 24591464(24015K) committed = 268435456(262144K) max = 2863661056(2796544K)
JVM Input Arguments : -Djava.util.logging.config.file=/opt/atlassian/jira/conf/logging.properties -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Xms384m -Xmx4096m -XX:InitialCodeCacheSize=32m -XX:ReservedCodeCacheSize=512m -Djava.awt.headless=true -Datlassian.standalone=JIRA -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true -Dmail.mime.decodeparameters=true -Dorg.dom4j.factory=com.atlassian.core.xml.InterningDocumentFactory -Djira.downgrade.allowed=true -XX:-OmitStackTraceInFastThrow -Djava.locale.providers=COMPAT -Djdk.tls.ephemeralDHKeySize=2048 -Djava.security.egd=file:/dev/./urandom -Djava.protocol.handler.pkgs=org.apache.catalina.webresources -Dorg.apache.catalina.security.SecurityListener.UMASK=0027 -Xloggc:/opt/atlassian/jira/logs/atlassian-jira-gc-%t.log -XX:+UseGCLogFileRotation -XX:NumberOfGCLogFiles=5 -XX:GCLogFileSize=20M -XX:+PrintGCDetails -XX:+PrintGCDateStamps -XX:+PrintGCTimeStamps -XX:+PrintGCCause -Dignore.endorsed.dirs= -Dcatalina.base=/opt/atlassian/jira -Dcatalina.home=/opt/atlassian/jira -Djava.io.tmpdir=/opt/atlassian/jira/temp
Java Compatibility Information : JIRA version = 8.7.0, Java Version = 1.8.0_202
___ Java System Properties _________________
atlassian.standalone : JIRA
awt.toolkit : sun.awt.X11.XToolkit
catalina.base : /opt/atlassian/jira
catalina.home : /opt/atlassian/jira
catalina.useNaming : true
common.loader : "${catalina.base}/lib",
"${catalina.base}/lib/*.jar",
"${catalina.home}/lib",
"${catalina.home}/lib/*.jar"
file.encoding : UTF-8
file.encoding.pkg : sun.io
ignore.endorsed.dirs :
java.awt.graphicsenv : sun.awt.X11GraphicsEnvironment
java.awt.headless : true
java.awt.printerjob : sun.print.PSPrinterJob
java.class.version : 52.0
java.home : /opt/atlassian/jira/jre
java.io.tmpdir : /opt/atlassian/jira/temp
java.locale.providers : COMPAT
java.naming.factory.initial : org.apache.naming.java.javaURLContextFactory
java.naming.factory.url.pkgs : org.apache.naming
java.protocol.handler.pkgs : org.apache.catalina.webresources
java.runtime.name : OpenJDK Runtime Environment
java.runtime.version : 1.8.0_202-b08
java.security.egd : file:/dev/./urandom
java.specification.name : Java Platform API Specification
java.specification.vendor : Oracle Corporation
java.specification.version : 1.8
java.util.concurrent.ForkJoinPool.common.threadFactory : org.apache.catalina.startup.SafeForkJoinWorkerThreadFactory
java.util.logging.config.file : /opt/atlassian/jira/conf/logging.properties
java.util.logging.manager : org.apache.juli.ClassLoaderLogManager
java.vendor : AdoptOpenJdk
java.vendor.url : https://adoptopenjdk.net/
java.vendor.url.bug : https://github.com/AdoptOpenJDK/openjdk-build/issues
java.version : 1.8.0_202
java.vm.info : mixed mode
java.vm.name : OpenJDK 64-Bit Server VM
java.vm.specification.name : Java Virtual Machine Specification
java.vm.specification.vendor : Oracle Corporation
java.vm.specification.version : 1.8
java.vm.vendor : Oracle Corporation
java.vm.version : 25.202-b08
jdk.tls.ephemeralDHKeySize : 2048
jira.downgrade.allowed : true
mail.mime.decodeparameters : true
org.apache.catalina.security.SecurityListener.UMASK : 0027
org.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER : true
org.dom4j.factory : com.atlassian.core.xml.InterningDocumentFactory
os.arch : amd64
os.name : Linux
os.version : 4.4.35-33.55.amzn1.x86_64
package.access : sun.,
org.apache.catalina.,
org.apache.coyote.,
org.apache.jasper.,
org.apache.tomcat.
package.definition : sun.,
java.,
org.apache.coyote.,
org.apache.jasper.,
org.apache.naming.,
org.apache.tomcat.
server.loader :
shared.loader :
sun.arch.data.model : 64
sun.boot.library.path : /opt/atlassian/jira/jre/lib/amd64
sun.cpu.endian : little
sun.cpu.isalist :
sun.io.unicode.encoding : UnicodeLittle
sun.java.command : org.apache.catalina.startup.Bootstrap start
sun.java.launcher : SUN_STANDARD
sun.jnu.encoding : UTF-8
sun.management.compiler : HotSpot 64-Bit Tiered Compilers
sun.os.patch.level : unknown
tomcat.util.buf.StringCache.byte.enabled : true
tomcat.util.scan.StandardJarScanFilter.jarsToScan : log4j-taglib*.jar,
log4j-web*.jar,
log4javascript*.jar,
slf4j-taglib*.jar
tomcat.util.scan.StandardJarScanFilter.jarsToSkip : annotations-api.jar,
ant-junit*.jar,
ant-launcher.jar,
ant.jar,
asm-*.jar,
aspectj*.jar,
bootstrap.jar,
catalina-ant.jar,
catalina-ha.jar,
catalina-jmx-remote.jar,
catalina-storeconfig.jar,
catalina-tribes.jar,
catalina-ws.jar,
catalina.jar,
cglib-*.jar,
cobertura-*.jar,
commons-beanutils*.jar,
commons-codec*.jar,
commons-collections*.jar,
commons-daemon.jar,
commons-dbcp*.jar,
commons-digester*.jar,
commons-fileupload*.jar,
commons-httpclient*.jar,
commons-io*.jar,
commons-lang*.jar,
commons-logging*.jar,
commons-math*.jar,
commons-pool*.jar,
dom4j-*.jar,
easymock-*.jar,
ecj-*.jar,
el-api.jar,
geronimo-spec-jaxrpc*.jar,
h2*.jar,
hamcrest-*.jar,
hibernate*.jar,
httpclient*.jar,
icu4j-*.jar,
jasper-el.jar,
jasper.jar,
jaspic-api.jar,
jaxb-*.jar,
jaxen-*.jar,
jdom-*.jar,
jetty-*.jar,
jmx-tools.jar,
jmx.jar,
jsp-api.jar,
jstl.jar,
jta*.jar,
junit-*.jar,
junit.jar,
log4j*.jar,
mail*.jar,
objenesis-*.jar,
oraclepki.jar,
oro-*.jar,
servlet-api-*.jar,
servlet-api.jar,
slf4j*.jar,
taglibs-standard-spec-*.jar,
tagsoup-*.jar,
tomcat-api.jar,
tomcat-coyote.jar,
tomcat-dbcp.jar,
tomcat-i18n-*.jar,
tomcat-jdbc.jar,
tomcat-jni.jar,
tomcat-juli-adapters.jar,
tomcat-juli.jar,
tomcat-util-scan.jar,
tomcat-util.jar,
tomcat-websocket.jar,
tools.jar,
websocket-api.jar,
wsdl4j*.jar,
xercesImpl.jar,
xml-apis.jar,
xmlParserAPIs-*.jar,
xmlParserAPIs.jar,
xom-*.jar
user.country : US
user.dir : /opt/atlassian/jira/bin
user.home : /root
user.language : en
user.name : root
user.timezone : US/Eastern
03-Aug-2021 00:26:50.570 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]
03-Aug-2021 00:26:50.576 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
03-Aug-2021 00:26:50.605 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 3927 ms
2021-08-03 00:26:50,628-0400 JIRA-Bootstrap INFO [c.a.j.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from /var/atlassian/application-data/efs/dbconfig.xml
2021-08-03 00:26:50,658-0400 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigHandler] Trying to get encrypted password from xml and decrypt it
2021-08-03 00:26:50,659-0400 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigHandler] Database password decryption not performed.
2021-08-03 00:26:51,275-0400 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger] Running JIRA startup checks.
2021-08-03 00:26:51,275-0400 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger] JIRA pre-database startup checks completed successfully.
2021-08-03 00:26:51,413-0400 JIRA-Bootstrap INFO [c.a.j.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from /var/atlassian/application-data/efs/dbconfig.xml
2021-08-03 00:26:51,419-0400 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigHandler] Trying to get encrypted password from xml and decrypt it
2021-08-03 00:26:51,419-0400 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigHandler] Database password decryption not performed.
2021-08-03 00:27:02,358-0400 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigurationManagerImpl] The database is configured. Now running Database Checklist Launcher
2021-08-03 00:27:02,362-0400 JIRA-Bootstrap INFO [c.a.jira.startup.DatabaseChecklistLauncher] JIRA database startup checks completed successfully.
2021-08-03 00:27:02,362-0400 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigurationManagerImpl] The database is configured. Now running Post database-configuration launchers
2021-08-03 00:27:03,547-0400 JIRA-Bootstrap INFO [c.a.j.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from /var/atlassian/application-data/efs/dbconfig.xml
2021-08-03 00:27:03,555-0400 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigHandler] Trying to get encrypted password from xml and decrypt it
2021-08-03 00:27:03,555-0400 JIRA-Bootstrap INFO [c.a.j.config.database.DatabaseConfigHandler] Database password decryption not performed.
2021-08-03 00:27:17,652-0400 JIRA-Bootstrap INFO [c.a.jira.upgrade.PluginUpgradeListener] [plugin-upgrade-listener] Created
2021-08-03 00:27:17,755-0400 JIRA-Bootstrap INFO [c.a.jira.startup.DatabaseLauncher] Database transactions enabled: true
2021-08-03 00:27:17,755-0400 JIRA-Bootstrap INFO [c.a.jira.startup.DatabaseLauncher] Using JIRA's default for database transaction isolation level: 2
2021-08-03 00:27:17,761-0400 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger]
Database configuration OK
___ Database Configuration _________________
Loading entityengine.xml from : file:/opt/atlassian/jira/atlassian-jira/WEB-INF/classes/entityengine.xml
Entity model field type name : postgres72
Entity model schema name : public
Database Version : PostgreSQL - 11.10
Database Driver : PostgreSQL JDBC Driver - 42.2.6
Database URL : jdbc:postgresql://jiradb-staging.caibfusn2myj.us-east-1.rds.amazonaws.com:5432/jiradb
Database JDBC config : postgres72 jdbc:postgresql://jiradb-staging.caibfusn2myj.us-east-1.rds.amazonaws.com:5432/jiradb
2021-08-03 00:27:17,833-0400 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger]
___ Starting the JIRA Plugin System _________________
Priya
KAGITHALA BABU ANVESH
August 2, 2021
Hello @Kurasi Vishnu Priya,
as per the KB, are you using the 42.2.6 JDBC driver?
Please check the below link for supported platforms
https://confluence.atlassian.com/adminjiraserver087/supported-platforms-998871472.html
Anvesh
Martin Bayer _MoroSystems_ s_r_o__
I think the driver is ok... log file contains:
Register today
