My Plugin Web Ressources doesn't work
Deleted user August 24, 2018
I make a plugin to execute some Javascript in all the pages of my JIRA Application.
The web-ressource in my file atlassian-plugin.xml :
 <web-resource key="test">
<ressource type="download" location="js/test.js" />
<context>alt.general</context>
</web-resource>
To test the plugin, I put only a console.log("OK") in the file test.js.
I load the plugin in JIRA, but the Javascript code doesn't work...
Note : the plugin work correctly because I have a web-item who work fine.
Deleted user September 19, 2018
Well...
I find the error...
It's just... ONE Character !!!
I write "ressource" with 2 "s"...
miikhy
September 19, 2018
Oh gosh...
Glad you've found it out! Could have taken more time!
Enjoyr the rest of your dev steps :)
Thank's Micky ^^ !
Deleted user September 3, 2018
Up
miikhy
September 3, 2018
Hey!
Still me, live from Summit! Have you tried using your own context instead of atl.* and include them in your Velocity templates with the resource manager? Never had issues with that!
Let me know :)
Cheers
Deleted user September 4, 2018 edited
I see some topics related to Velocity, but I don't understand exactly what it that...
I don't try this so.
You can give me a basic example :) ?
Basically, i want to put a Javascript librarie on each page of my JIRA application, to use it with the plugin JSIncluder.
Deleted user September 11, 2018
Up
miikhy
August 27, 2018
Hi Raphaël,
Have you tried using atl.general? :) (mispelled in your example).
Cheers
Deleted user August 28, 2018
Oops thanks.
But it still doesn't work :( ...
Like 김진식 likes this
miikhy
August 28, 2018
In my plugins I have the following:
<resource type="download" name="filename.js" location="/js/filename.js"/>
<context>myContext</context>
And the path is src/main/resources/js/filename.js
Could you try with the leading "/" ?
Also, inputing an alert is not a good idea to test as the resource can be loaded before page render, what I've done in the past is more defining vars and checking them in console or:
AJS.$(document).ready(function() {
    alert('test');
which ensures the body is ready before popping the alert.
Let us know if it worked!
Cheers
I also try with the "/", but nothing change...
I prefer put a console.log because its non-blocking, so I try like this :
console.log("OK");
But same result : nothing in my console...
miikhy
August 29, 2018
Have you tried using context, not global context? I can't use the SDK now to check atl.general but never had problems with specific ones!
Have you also made sure to refresh your localhost:2990/jira page with no cache (shift + refresh)? New javascript resources are always lagging on my laptop for instance and I've been very frustrated before discovering a simple cache refresh made it work sometimes!
Hope this helps!
Cheers
Deleted user August 29, 2018
I also try atl.admin but nothing.
I test my plugin on a different instance (because my localhost:2990/jira doesn't work fine...), I try to refresh cache (ctrl + f5, and shift + f5) but... nothing.....
I don't understand why.
