We have configured a Auto Transition Listener in Jira to reopen a closed or resolved issue upon comment. It worked fine before, but in the last few days I have noticed that Issues being commented ar not being reopened.
Do anyone know where I can truobleshoot? In Listeners config it looks fine.
This is my listener setup:
We have upgraded Jira to the latest version and then I deleted the listeners I had created before and put up new ones to test them, and now they WORK :)
I followed this thread and put in the same:
So now our listener looks like this:
Which operating system do you have Jira installed in? Are you using an on-demand or downloaded version of Jira?
On our windows machine, the atlassian-jira.log file is located in C:\Program Files\Atlassian\Application Data\Jira\log.
If you've installed Jira somewhere other than your Program Files directory, you should just search your machine forthe atlassan-jira.log file.
The logs might have some helpful information. Also look at the workflow to see if any new workflow conditions or validators were added which is now preventing the transition.
