NPE with jira eclipse connection
Henry Floyd March 25, 2015
Anyone else have this problem with the eclipse JIRA connector?
!ENTRY org.eclipse.mylyn.tasks.core 4 0 2015-03-25 14:15:57.197
!MESSAGE Synchronization failed
!STACK 0
java.lang.NullPointerException
    at com.atlassian.connector.eclipse.internal.jira.core.service.rest.JiraRestConverter.isVersionMissingInProjectCache(JiraRestConverter.java:324)
    at com.atlassian.connector.eclipse.internal.jira.core.service.rest.JiraRestConverter.convertIssue(JiraRestConverter.java:269)
    at com.atlassian.connector.eclipse.internal.jira.core.service.rest.JiraRestClientAdapter$5.call(JiraRestClientAdapter.java:324)
    at com.atlassian.connector.eclipse.internal.jira.core.service.rest.JiraRestClientAdapter$5.call(JiraRestClientAdapter.java:1)
    at com.atlassian.connector.eclipse.internal.jira.core.service.rest.JiraRestClientAdapter.call(JiraRestClientAdapter.java:744)
    at com.atlassian.connector.eclipse.internal.jira.core.service.rest.JiraRestClientAdapter.getIssues(JiraRestClientAdapter.java:314)
    at com.atlassian.connector.eclipse.internal.jira.core.service.JiraClient.findIssues(JiraClient.java:368)
    at com.atlassian.connector.eclipse.internal.jira.core.service.JiraClient.findIssues(JiraClient.java:360)
    at com.atlassian.connector.eclipse.internal.jira.core.service.JiraClient.search(JiraClient.java:755)
    at com.atlassian.connector.eclipse.internal.jira.core.JiraRepositoryConnector.performQuery(JiraRepositoryConnector.java:140)
    at org.eclipse.mylyn.internal.tasks.core.sync.SynchronizeQueriesJob.synchronizeQuery(SynchronizeQueriesJob.java:312)
    at org.eclipse.mylyn.internal.tasks.core.sync.SynchronizeQueriesJob.synchronizeQueries(SynchronizeQueriesJob.java:269)
    at org.eclipse.mylyn.internal.tasks.core.sync.SynchronizeQueriesJob.run(SynchronizeQueriesJob.java:201)
    at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
jjaroczynski
March 25, 2015
Hi Henry,
I've raised https://ecosystem.atlassian.net/browse/PLE-1582.
What is your Connector version?
UPDATE: I believe you use 3.2.4 snapshot and this bug was introduced when working on the other issue for 3.2.4 (so the stable 3.2.3 is not affected).
I have fixed this NPE so please upgrade and let us know if everything is fine (3.2.4 snapshot have been rebuilt and contains the fix)
Jacek
