Hi guys
I suspect this is related to the stemming issue reported by Bettina, but wondered if there was any update on this:
I have a two dimensional filter with country (using natural text searcher) on one axis, and the other is priority
the labels for country are not shown at all, but the source data is stemmed
When you click through, you can see the stemming is active, as the country field referenced is 'zealand' rather than 'new zealand'
It's exactly the same for exact text searchers, but I don't want to use those due to case sensitivity
Any thoughts on how to resolve this, as I do need a stattable field result, that also displays it's labels appropriately
Cheers
hi,
be changing the code , we can make a new searcher that is case insensitive : that would be a "exacte text searcher - case insensitive"
what version of jira are you using currently ?
Hi Marc
I'm running 5.2.11 on our live system, and 6.0.8 on our test and development system
I've been looking at your stattable searcher project, which looks pretty good... I'm seeing if I can modify the sources to get it compiling with 5.2.11
Ok - have discovered that since I was doing a background reindex, the issue persisted
I switched to the natural searcher (exact) and it returns the correct table and values
However, searching is now case sensitive (which I wanted to avoid!)
Any thoughts on resolving this?
Learn more
