Need Help To REST Call
Kumar
April 2, 2019
Hi Team,
Recently I have Tried REST Call to Create a Instance in AWS by using the "Easy Integrations for JIRA"  its  a free add-on
adding a jira Post-function on a particular Workflow transition.
so, when ever the workflow transition got executed it will automatically creates a instance in AWS.
So, here I need By Selecting the Value Selected i the Dropdown List the REST needs to call
example:
Select List Options: AWS
AWS instance Type: t2.micro, t2.nano, t2.small, etc.,
Owner: text Field
in the Work Flow Post Function i have choose the "REST Call" option
and i have added the
URL :  http://aws_create_ec2_instance
 Header : Content-Type: application/json
Request: Post
Request Body : {"location":"aws","instance_type":"t2.nano","owner":"xyz", "cost_center":68687}
I published the  workflow.
Now, when i create a issue if i execute that particular transition which i added the "Rest call"
post function it will create a ec2 instance in the give url location
Now I want if i give another Values like "AWS, instance type: t2.nano, " if i execute the same
transition i need to create the another instance with the value given in the custom field.
Depends upon the value given need to Call related REST  apis
can anyone suggest me how to achieve this
Kumar
