×Hi Guys,
Need your help in sending REST API from Scriptrunner script console.
I'm trying to see below POST HTTP request, but getting 404 error. I think some issue in my code, please help me in fixing the code :-
import groovy.json.JsonOutput
import groovyx.net.http.ContentType
import groovyx.net.http.HttpResponseDecorator
import groovyx.net.http.RESTClient
final externalUrl = "https://api.openai.com/v1/completions/"
def body = JsonOutput.toJson(
"model": "text-davinci-003",
"prompt": "Q:do you know if we have an Advanced Roadmap plugin running in Jira cloudand please share latest Atlassian Document Link?AI:",
"temperature": 0,
"max_tokens": 100,
"top_p": 1,
"frequency_penalty": 0,
"presence_penalty": 0,
"stop": ["\n"]
def postResponse = post(externalUrl, "", body)
if (getResponse) {
def responsePostMap = postResponse as Map
responsePostMap.each {}
assert responseStatus == 200
def post (def hostUrl, def endpointAndQuery, def bodyJson)
def client = new RESTClient(hostUrl)
client.setHeaders([
'Accept' : ContentType.JSON,
'Authorization' : "Bearer sk-j4qZQqwSRgElbkFJbALfxVk99xgsfiJmTlm4"
client.post(
path: endpointAndQuery,
contentType: ContentType.JSON,
body: bodyJson
You should let the RESTClient handle the body conversion.
Just create a groovy map object and pass that as the body.
def body = [
model: "text-davinci-003",
prompt: "Q:do you know if we have an Advanced Roadmap plugin running in Jira cloud and please share latest Atlassian Document Link?AI:",
temperature: 0,
max_tokens: 100,
top_p: 1,
frequency_penalty: 0,
presence_penalty: 0,
stop: ["\n"]
def post(def hostUrl, def endpointAndQuery, def bodyJson) {
client.setHeaders([
'Authorization': "Bearer sk-j4qZQqwSRgElbkFJbALfxVk99xgsfiJmTlm4"
client.post(
body: bodyJson
If you still get an error, then check back on the documentation of the target endpoint.
404 usually means that you have specific a wrong endpoint.
Or ask an OpenAI bot to fix the problem?
Hi @PD Sheehan and @Radek Dostál Thanks for your help!
But still getting error while same POST request is working fine in POSTMAN.
Error Message :- groovyx.net.http.HttpResponseException: status code: 404, reason phrase: Not Found at groovyx.net.http.RESTClient.defaultFailureHandler(RESTClient.java:263) at groovyx.net.http.HTTPBuilder$1.handleResponse(HTTPBuilder.java:503) at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:223) at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:165) at groovyx.net.http.HTTPBuilder.doRequest(HTTPBuilder.java:515) at groovyx.net.http.RESTClient.post(RESTClient.java:141) at groovyx.net.http.RESTClient$post.call(Unknown Source) at Script1959.post(Script1959.groovy:34) at Script1959.run(Script1959.groovy:21)
This is the working cURL command, you can test on your machine as well , it works fine :-
curl --location 'https://api.openai.com/v1/completions' \
--header 'Content-Type: application/json' \
--header 'Authorization: Bearer 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' \
--data '{
"prompt": "\\n\\nHuman:do you know if we have an Advanced Roadmap plugin running in Jira cloud and please share latest Atlassian Document Link?\\nAI:",
"temperature": 0.9,
"max_tokens": 150,
"top_p": 1,
"presence_penalty": 0.6,
"stop": [" Human:", " AI:"]
Ah I see, the other issue was that you can't include the path in the URL when creating the client then try to set it to empty when calling the post method.
Try it like this (I also added a failure handler):
final externalUrl = "https://api.openai.com"
def body = [
temperature: 0,
max_tokens: 100,
top_p: 1,
stop: ["\n"]
def postResponse = post(externalUrl, "/v1/completions", body)
client.setHeaders([
client.handler.failure= { HttpResponseDecorator response ->
log.error "POST Error: $response.uri" //unfortunately, I don't know how to confirm the actual full uri
log.error response.entity.content.text
return [:] //return an empty map
client.post(
requestContentType: ContentType.JSON,
body: bodyJson
