Need Help with Field Configurations
steve tolson November 6, 2013
I've setup Jira so that I have three issue types. For each issue type I would like to show different field configurations. I've setup one issue type and it shows the desired field configs when I create a new task. However, the others do not show up correctly?
What should I check?
SanaS
November 6, 2013
Check the Field Configuration Scheme for your project. That's where you associate Field Configurations with the issue types that you desire. You can create a new Field Configuration Scheme from Admin -> Issues -> Field Configuration Schemes, and then go to your project and select that scheme to be put in use.
Register now
