Hi. I want to fetch issues based on Certain Components List and need to use wild cards on components.
For eg: project="X" AND component in componentMatch("Issue Type:*")
where in the component list includes Issue Type:X, Issue Type:Y - basically I want to fetch issues related to any of the components starting with Issue Type : (any word).
I tried this above query
It is not showing any error but not returning results as well. Any solution for this??????
Hi Aishwarya Rajan,
Sadly you cannot achieve the desired search using standard features on Jira, you must go for a third-party app instead. Using i.e. JQL Booster Pack you can type the following:
Search issues with components starting with 'Issue Type:' on Project EMEA
project = EMEA AND component IN componentMatches("Issue Type:.*")
Using this app you can also query other fields using regexp, check:
References:
Hope this helps you to create awesome queries <3
Kind regards
Hi Alexey,
I tried the query.. it doesn't show error but does not return any results. We have prod n dev environment in jira. My query works in dev environment..but not in prod. I have tried with component Matches method too. That works in dev again n not in prod. So is it dependent on any supporting plugins or add on..that we need to install?
This JQL function is from the ScriptRunner plugin
We have scriotRunner in prod. But still componentMatch is not working in prod. Any help on this would be appreciated.
Also,
component Matches works if we install JQL booster pack. But why isn't componentMatch not working?.
Are you sure that you have such components in prod and there are issue with these components set?
Also you can have problems with indexes in prod
You can find more info on indexes here:
https://confluence.atlassian.com/jirakb/jira-indexing-faq-776654790.html
It must be like this
project="X" AND component in componentMatch("Issue Type:.*")
Save your spot
